... , 5 . . : http://www.webalice.it/hotwater/RTX5x20.htm.
Noise Floor: ~70nV (-130dBm)@3dB S+N/N
Sensitivity: 0.14uV (-124dBm)@10dB S+N/N
, , . , , .. ( ), - " 5 ..." - 5 , IC-7700, Elecraft K3 - "" .
TEST RESULTS
RX OPERATION
Blocking (deltaF=50KHz): -46dBm
Blocking (deltaF=10KHz): -50dBm
3rd order IMD (deltaF=25KHz): -66dBm
3rd order IMD (deltaF=100KHz): -66dBm
IMD dynamic range: 64dB
Calculated IPC (ARRL method): -34dBm
2nd order IMD (8+6=14MHz): -26dBm
2nd order IMD (22-8=14MHz): -16dBm
IF rejection: 92dB
Image rejection: 96dB
S9 reading: 50uV
NOTE: tests as described in RadioKitElettronica 5/99
TX OPERATION
Power: 5.5W PEP
Carrier suppression: >33dB
2nd harmonic: ~40dB below fundamental
3rd harmonic : >50dB below fundamental
, :RX1AL
.RX1AL
(deltaF = 50KHz):-46dBm
Blocking (deltaF=10KHz): -50dBm (deltaF = 10KHz):-50dBm
3 rd order IMD (deltaF=25KHz): -66dBm 3- IMD (deltaF = 25KHz):-66dBm
3 rd order IMD (deltaF=100KHz): -66dBm 3- IMD (deltaF = 100kHz):-66dBm
IMD dynamic range: 64dB IMD : 64dB
Calculated IPC (ARRL method): -34dBm IPC (ARRL ):-34dBm
2 nd order IMD (8+6=14MHz): -26dBm 2- IMD (8 +6 = 14MHz):-26dBm
2 nd order IMD (22-8=14MHz): -16dBm 2- IMD (22-8 = 14MHz):-16dBm
, " ". , . .YES
73 !
, , , , . , , , . , . . - , , , .. , "" 4- , , ! "" 4 .... ! - ! , 6-8 ... ! - ... !!!
: 1 (: 0 , : 1)
