Наверно более правильно в этой ветке
А Hermes всё ближе и ближе Небольшой отчёт:http://hpsdrhermes.blogspot.com/ И видео:http://www.youtube.com/watch?v=NyYRs8dzapY
Что то первая ссылка не работает.Что там то было,прокоментируйте .
Последний раз редактировалось WladN; 29.07.2011 в 13:15.
У меня работает
Полный текст:
I finished the PCB design and assembly on the Hermes Ethernet prototype a few weeks ago but due to work I had no time for the first blog post till now,
i guess it’s better late than never.
The design team includes:
Kevin Wheatley M0KHZ who conceived the Hermes and is the Project Lead
Abhi Arunoday PCB layout
Phil Harman - VK6APH - Software & hardware development
Bill Tracey - KD5TFD - Component sourcing and kitting
Lyle Johnson - KK7P - hardware development
Scotty Cowling - WA2DFI – Parts procurement
Graham - KE9H - Hermes PA
Apollo, a companion 20W PA, LPF and ATU and the Hermes SMPS was conceived by Kjell Karlsen – LA2NI
I must mention that Phil did a wonderful job on the verilog code, initially I had some grief due to a faulty chip but once I replaced it the original code works flawlessly!
(this code was written by Phil even before the PCB was ready).
The board is 8 layers and with 3 clocks at 1.5v PP, multiple frequencies being generated by the FPGA, high signal speeds on the PHY and the extremely sensitive Rx
front end make the routing, placement and the ground plane system extremely critical.
Initial tests look very good; there are 6 spurs within the HAM bands from 160M through 6M, most will fall below the noise floor with the antenna connected. Noise
floor is within 2dB across all bands and sensitivity measures at about -136dB on 20M with preamplifier ON.
Transmitter tests look promising too......all harmonics and spurious outputs are well below 45dB.
Спасибо.Команда солидная,аппарат готовят серьезно,8ми слойная...!!!
Скорее бы уж! Так хочется DDC трансивер, аж зудит везде!
Последний раз редактировалось WladN; 29.07.2011 в 20:07.
По параметрам сравнивали с Flex-5000,субьективно флекс послабее будет,а делать инструментальные замеры не собираюсь,меня устраивает,
доказывать,лучше-хуже ну нет желания.Минусы-те же,что и у всех трансиверов с программой PSDR,хотя в телеграфе вроде задержки не заметно.Ну и главный минус,правильно Владимир заметил,куча платочек в не очень удобном форм-факторе.Тут Гермес вне конкуренции.ОК,будем ждать,тоже интересуюсь.
У проекта Гермес свои прелести ,у HPSDR свои ,одноплатный вариант это конечно интересно , но там было очень много проблем по разводке ,сам проект отработан и не плохо работает в двух вариантах, один это приемник QS1R ,другой это трансивер HPSDR.Да ясогласен ,хотелось бы увидеть программное обеспечение все таки свое ,а не PSDR.
