Страница 87 из 148 ПерваяПервая ... 37778485868788899097137 ... ПоследняяПоследняя
Показано с 861 по 870 из 1479
Тема: SDR и соревнования
  1. #861
    Да :-))))
    73 ! Anton, MW0EDX & MW5R
  2. #862
    Что-то весь вокруг-сдр-спорящий бомонд ушел на щрз.ру, надо восстановить баланс и тут :-)
    Вычитал в рассылке мнение Роба Шервуда о том, что ему не понравилось в флексах 6700 и 6300+маэстро при использовании в контестах:
    Скрытый текст
    Rob Sherwood.
    Dec 24, 2017
    I want to clarify the statement below about me abandoning Flex for contesting. Back in 2014, I used a Flex 6700 in the January CQWW 160m CW contest, and then in December of the same year I used the same 6700 in both the ARRL 160m CW and ARRL 10m contests. The loaner radio was then returned to Flex.
    The next time I ran a Flex radio was January of 2017 during the same CQWW 160m CW contest. It was a 6300 with a Maestro interface. I had all sorts of what I assume were software-related problems. Timing issues, QSK issues, AGC and muting issues, and the noisy CODEC in Maestro. At 1:30 AM on Sunday I went back to the IC-7300, which had none of the above mentioned problems.
    I will be borrowing a 6600M and a 6400 from a friend of mine, and depending on when the radios actually ship, I’ll run them in contests. I try to evaluate all new transceivers both in the lab and during major contests. I run single op, non-assisted, both CW and SSB. On CW I only do S&P. I have no idea whether the software issues I experienced 11 months ago with the 6300 will be resolved with the 6400. I certainly hope so. I am told that the 6600M will ship before the 6400. It is questionable that I will have access to any new Flex products for CQWW 160m CW in January 2018. That means the next CW contest I will run won’t be until December 2018. The only remaining contest for me in early 2018 will be ARRL SSB in March.
    Rob Sherwood
    NC0B
    Читаем в оригинале или самостоятельно переводим автопереводчиками...
  3. Спасибо от K2PAL, UR5LAM
  4. #863
    У каждого свой опыт.
    Я могу констатировать лишь одно - у меня сейчас два сетапа:
    1. SunSDR2 + HLA300 + LDG AT600Pro 300W
    2. TS-2000 + PW1 1200W
    И я за месяц второй сетап ни разу не включил - не интересно. Да, с SDR куча неудобств, есть свои проблемы , но с с классикой - не цепляет, вот и весь ответ.
  5. Спасибо от K2PAL, UA6AA, UT0UM
  6. #864
    Спасибо за мнение. Посмотрим, поменяется ли оно через пол года-год.
    Кстати, чего ПВ-1 пошел на продажу? (видел объявление)
  7. #865
    Он не втыкается в сеть 110 В, которая вскоре будет в мои розетках.
    К тому же его трудно запихнуть в транс-атлантический самолет (тяжелый зараза)
  8. Спасибо от Serg
  9. #866
    В SunSDR2 и HLA300 я учел этот момент - там универсальный блок питания, который может питаться и от 220V и от 110V.
    LDG AT600 так же позволяет согласовать любую веревку где угодно - мне это очень пригодится.
  10. #867
    Ни-Но область
    1,007
    Розетки в Канаде?
  11. #868
    А у меня FT1000D в качестве полки пока не продам его и IC-7300.
    И оставляю SunSdr и два усилителя Hla-300V и ACOM-A1000.
  12. Спасибо от UT2UU
  13. #869
    KE-27
    5,883
    UA8U (ex RZ9UI, RA9UGR)
    Это написано AG2T сегодня, но в другой теме: "ExpertSDR2 – 5MContest все запустил, кроме CW Skimmer.
    Времени не осталось, завтра уже тест.
    Пока поработаю на IC-7300+N1MM.
    Мучался с сетапом заметил, что-то не хорошее, вдруг на 15мс прекращает работать программа какой-то типа возбуд появляется hash и конечно возобновляет работу, но это меня не радует и еще баг на 40м даже физически отключаю антенну, картинки прикрепил, а вот с антенной этого почти нет.Блок питания менял и даже аккумулятор ставил.
    Буду отправлять, я на нем, черт побери и не работал." Хорошо, что не продали IC-7300.
  14. #870
    Аватар для Алексей В. И.
    Бутурлиновка, VR-17
    77
    R2OM
    Ссылочку бы.
    Здесь SunSDR-1 (EE-SUNSDR-15M1S)
    Железо древнющее:
    Из-за слабости железа, не могу пользовать родную ESDR2.1.4.21 (на диске прилагалась).
    Здесь PowerSDR и Дельта44
    Для CW тестов - TR4W . Очень удобна. Ресурсов не жрет. Единственный недостаток - не видет OmniRig.
    Для остальных (не CW) - MixW. Но, хоть я ключ и купил для MixW3, для тестов установил 2.19, ибо укузюкало в третьем миксе, при каждом занесении связи в лог, смотреть на песресчет (занимает 1...2 сек.).
    Работаю без УМ. Заявляюсь как LP.
  1. Предлагаю Соревнования - Ретро.
    от R0SBD в разделе Соревнования
    Ответов: 102
    Последнее сообщение: 03.01.2012, 12:36
  2. Соревнования на призы портала CQ-VRN.RU
    от RX3QFY в разделе Соревнования
    Последнее сообщение: 07.04.2010, 19:37
  3. Соревнования радиолюбителей Калмыкии
    от Очир в разделе Соревнования
    Ответов: 30
    Последнее сообщение: 11.01.2010, 11:54
  4. УКВ-соревнования памяти Г.А.Румянцева UA1DZ
    от ua3pno в разделе УКВ соревнования, дипломы
    Последнее сообщение: 31.01.2009, 22:34
  5. Соревнования в формате iCalendar?
    от UB9HCE в разделе Для любителей КВ
    Последнее сообщение: 12.10.2007, 23:41
