Да.
Да.
Спасибо от *RJ
Провел ряд экспериментов с генератором Франклина. При отсутствии конденсатора обратной связи или при емкости его 5пф, очень резкий скачок возникновения генерации, сразу с 1.5МГц до 18МГц. Если конденсатор обратной связи увеличить до 56пф, плавное нарастание частоты от 1МГц !!! до 42Мгц, при полном использовании переменного сопротивления. Заметил, если вместо 470 ом поставить 1 ком, стабильность повышается, на частоте 20-42МГц частотомер пляшет в пределах +- 10-15кГц. Для регенератора, конечно, не годится, а вот для широкодиапазонного генератора - как раз! Может я не там регулирую? Хотелось бы без изменения частоты плавный подход к генерации.
Скрытый текст
A regenerative receiver for the 40 m band
I've had a lot of fun with the modified WBR (Wheatstone Bridge Regenerative) receiver
which I built Manhattan-style some years ago. The design builds
on the receiver described by Daniel Wissell, N1BYT in QST August 2001.
Although it doesn't match a good superheterodyne, you get more performance
per component than in any other receiver!
Unlike other regens I have tried, it is stable enough to listen to
CW/SSB. It is also easy to operate. Much of this is attributed to the small tuning range
and the separate oscillator circuit. Mine tunes from 7.0 to 7.28 MHz.
The WBR is a regenerative receiver with good isolation from the antenna and with little
interaction between tuning and regeneration controls. The WBR has a JFET detector
and a separate oscillator for the regeneration, plus an LM386 audio amplifier.
WBR = Wheatstone Bridge Regen, and that is the unique part of it, a sort of a balanced
input circuit with very loose coupling to the antenna for minimizing radiation.
In my opinion the original design has too little audio gain even in Europe. I added that
by using ideas from 7N3WVM. His receiver is basically the same receiver except for the
Wheatstone bridge in the front-end. The modifications to the N1BYT design
is the addition of audio gain (NPN transistor between JFET and LM386)
and an audio gain control.
Thus my version combines the best features of the original
WBR 7 MHz receiver from N1BYT and some more audio gain and an audio pot according
to the related 7N3WVM receiver.
According to my check it has a sensitivity of around 30 uV.
Регенеративный приемник для диапазона 40 м
Мне было очень весело с модифицированным приемником WBR (регенеративный мост Уитстона),
который я построил в манхэттенском стиле несколько лет назад. Конструкция построена
на приемнике, описанном Дэниелом Висселом (Daniel Wissell), N1BYT, QST, август 2001 г.
Хотя он не соответствует хорошему супергетеродину, вы получаете большую производительность
на компонент, чем в любом другом приемнике!
В отличие от других регенов, которые я пробовал, он достаточно стабилен для прослушивания
CW / SSB. Это также легко работать. Во многом это связано с небольшим диапазоном настройки
и отдельным контуром генератора. Мои настройки от 7,0 до 7,28 МГц.
WBR является регенеративным приемником с хорошей изоляцией от антенны и с небольшим
взаимодействием между настройкой и управлением регенерацией. WBR имеет детектор JFET
и отдельный генератор для регенерации, а также усилитель звука LM386.
WBR = мост Уитстона Regen, и это его уникальная часть, своего рода сбалансированная
входная цепь с очень слабой связью с антенной для минимизации излучения.
На мой взгляд, оригинальный дизайн имеет слишком мало звука даже в Европе. Я добавил это,
используя идеи из 7N3WVM. Его приемник в основном такой же, за исключением
моста Уитстона во внешнем интерфейсе. Модификацией конструкции N1BYT
является добавление усиления звука (транзистор NPN между JFET и LM386)
и управление усилением звука.
Таким образом, моя версия сочетает в себе лучшие характеристики оригинального
ресивера WBR 7 МГц от N1BYT и еще немного усиления звука и звука в соответствии
с соответствующим ресивером 7N3WVM.
Согласно моей проверке он имеет чувствительность около 30 мкВ.
Последний раз редактировалось sgk; 21.01.2019 в 15:06. Причина: Язык форума
Спасибо от *RJ
ПапА, спасибо! Сегодня сделаю, посмотрю, что получится, самому тоже пришла мысль сделать отрицательную связь, объединив смещение. Одинаковые мысли иногда у людей бывают. По этой схеме такое впечатление, что это релаксатор, ну не может контур с такими параметрами генерить от 1до42МГц, надо замерить напряжение при разных частотах в разных точках, жаль осцилографа нет, посмотреть форму сигнала.
Последний раз редактировалось Hello; 20.01.2019 в 09:51.
Хотя и так делалось. Читал где-то, что если напряжение от эмитера до общего провода превышает учетверенное напряжение Б-Э, то есть больше 2,7 вольта, то никаких особых мер термостабильности применять не нужно если конечно схема специально не предназначена работать в морозильнике и в печке.
Последний раз редактировалось ПАПА; 20.01.2019 в 10:25.
Проверил, сопротивление на землю на базе второго транзистора полностью блокирует генерацию при любом положении КПК и переменного сопр. Стабильность и диапазон генерируемых частот сократился при уменьшении сопротивлений в цепях баз до 82ком. Вывод: при первичных значениях генератор имеет уникальные сво-ва перестраиваться от 42МГц до1МГц. Попробую увеличить сопротивления в цепи баз до 470ком.по первичной схеме.
Поиграюсь с индуктивностью контура.
Нового ничего не придумать, все уже украдено из матрицы жизни до нас!
https://ru.wikipedia.org/wiki/Мультивибратор
Зависит от конкретной ситуации, но, лучше поступать формально-консервативно по ГОСТу: включать на вход эквивалент сопротивления источника.
Спасибо от parrot
...Тут http://foto1.inbox.lv/ninni/shemas-c...ultiregens.jpg можно "полюбопытствова ть" на регенераторы нашего коллеги из Литвы.
Спасибо от wolf1605
