Что такоё "идеальный смеситель для ППП" ?Сообщение от Alfred
http://www.cqham.ru/trx41_01.htm
У US5MSQ в некоторых схемах он то же стоит. В журнале радио Он как "УСИЛИТЕЛЬ за счёт трансформации" используется.
Олег, у вас ICQ клиент есть? Мой 241535295
Mixer (MC3008)
ideal RF mixer.
RF mixers convert RF power at one frequency into power at another frequency to make signal processing easier and more efficient. The frequency that is to be shifted is applied at the RF input and the frequency shifting power or voltage (from a local oscillator, LO) is applied to the RF mixers LO port, resulting in two outputs at the mixer Intermediate Frequency (IF) port. For a given RF signal, an ideal mixer would produce only two IF outputs: one at the frequency sum of the RF and LO, and another at the frequency difference between the RF and LO. Filtering can be used to select the desired IF output and reject the unwanted one, which is generally called the IF image. Configurations available for RF mixers can be surface mount, flat pack, through hole or plug-in, connectorized, and waveguide assembly.
Important performance specifications to consider when searching for RF mixers include RF frequency range, LO frequency range, IF frequency range, conversion loss, and LO power. RF frequency range is the range of input (RF) frequencies that the mixer was designed to work with. A LO (Local Oscillator) is an oscillator used in superheterodyne receivers which when mixed with an incoming signal results in a sum or difference frequency equal to the intermediate frequency of the receiver. IF (Intermediate Frequency) is the frequency to which all selected signals are converted for additional amplification, filtering, and direction. Conversion loss is defined as the loss of power between the input RF signal and the output IF signal during the frequency translation. It is calculated as the ratio (in dB) of the IF output power to the RF input power. It is a measure of the efficiency of the mixer in providing frequency translation between the input RF signal and the output IF signal. All conversion loss measurements are normally based on the mixer being installed in a 50 Ohms system and a stated LO signal power specified according with the appropriate mixer type. LO power is the power level (in dBm) that must be supplied by the local oscillator to properly drive the mixer diodes. The LO power is a very important factor in determining the values of IP3, 1 dB Compression Point and Dynamic Range of a mixer.
Isolation is also important to consider when specifying RF mixers. Isolation is a measure of the circuit balance within the mixer. It is the level of attenuation of a signal injected into a specific port when measured at a different port. When the isolation is high, the amount of "leakage" or "feed thru" between the mixer ports will be very small. Isolation is formally defined as the ratio (in dB) of the power level applied at one port of the mixer to the resulting power level at the same frequency appearing at another port. LO isolation is the isolation from the LO port to the RF port. It is the degree of attenuation of the LO signal measured at the RF port with the IF port properly terminated. LO-IF isolation is the isolation from the LO port to the IF port. It is the degree of attenuation of the LO signal measured at the IF port with the RF port properly terminated. Common mixer types available include single balanced mixer, double balanced mixer, triple balanced mixer, quadrature IF mixer, and image reject mixer. An important environmental parameter to consider when searching for RF mixers includes the operating temperature.
Model MC3008, the latest from Cougar’s line of high performance, double-balanced, frequency mixers, covers RF frequencies from 1 to 3400 MHz, LO from 1 to 3400 MHz, and IF from 1 to 2000 MHz. This 10 dBm LO drive mixer provides typical conversion loss of 6.0 dB from 5 to 1000 MHz and 8.0 dB from 1 to 3400 MHz. Typical isolation (fL at R) ranges from 40 to 43 dB, and 35 to 40 dB (fL at I). Typical conversion loss is 6.0 dB, and third-order intercept point is 20 dBm typical. The MC3008 comes standard in a TO-8 package, and is also available in a SMA connectorized package.
Applications include: aerospace, space, military, industrial and commercial.
MIL-PRF-38534 and ISO 9001 certified.
Теперь понятно о чём разговор. Чтобы в Вашей схеме использовать трансформатор, как у Г. Брагина, нужно задействовать в смесителе не 4 ключа а 8. У Вас схема SSB смесителя с выходами 0, 90, 180, 270 градусов, а в качестве примера приводите схемы DSB с выходами 0, 180 градусов. Также важно уточнить длительность импульсов гетеродина - 1/4 или 1/2 периода, от этого зависит вид соединения входов ключей. ICQ нет, пишите в ЛС.Сообщение от Alfred
О цэ мы накалбасили на ночь глядя.
Теперь проясните мне несколько вопросов пожалуйста:
1) В чём отличие смесителя Var 1 от Var 2 в качественных показателях
(простыми словами какой из них лучше будет работает и ПОЧЕМУ!)
2) Как правильно(корректно) расчитать С14С15L2 и С31С32L5, если с одной стороны мы имеем сопротивление переходаов + R1,R21 и тогда С14 должен для полосы 3кГц иметь >0.2мкФ, а с другой 60кОм входного сопротивления усилителя, и тогда эта ёмкость должна быть >10нФ.
Собсно покритикуйте, пока не напаяли зря....
Да, ещё предложите схемку каскада с АРУ с минимально возможными нилинейными искажениями. Только желательно что бы громкость регулировалась не на динамике (как тут было несколько подобных схем в т.ч. и в журнале Радио), а можно было бы поставить любой оконечник по желанию.
Доброй ночи!
To Alfred
Лучше Var 3 – во вложении Var 3.gif . Если нужна АРУ с малыми искажениями (<0.15%) то вложение АРУ xssd.gif , питание ОУ берётся из точки соединения R13 и C10 (на схеме не показано). При больших допустимых искажениях (<2%) схему можно и попроще. Далее – после активного ФНЧ Чебышева 4-го порядка на NE5534 Вы поставили пассивный LC ФНЧ. Какой в этом смысл ? На мой взгляд стоит применить либо хороший активный ФНЧ на 3-х ОУ, либо пассивный с тремя или более катушками. Из НЧФВР убраны подстроечники, это ведёт к необходимости подбора конденсаторов и резисторов с точностью 1%.
Олег, у вас на схеме в точках соединения R9R20 не было смещения Uп/2. Я ввёл его R13R14 - это корректное включение ОУ в данной схеме?
В схеме АРУ DA1.1 и DA1.2 можно применить сдвоенный ОУ 5532, а DA2 - 5534?
R13, R14, C25 нужно убрать. Смещение подаётся с выходов К157УЛ1 через R8 и R22.Сообщение от Alfred
NE5534 в качестве DA2 подойдёт прекрасно. NE5532 в DA1.1 и DA1.2 попробуйте. Если при работе АРУ появятся щелчки придётся скомпенсировать входной ток DA1.1, добавив три резистора, схема во вложении. Переменным резистором 10к устанавливается равенство напряжений на входе и выходе с точностью 1 мв. Китайского цифрового тестера для этого достаточно.Сообщение от Alfred
Что Вы решили с фильтром, и какой схемой собираетесь получать напряжения гетеродина 0, 90, 180 и 270 градусов?
