hOne, скорее всего вам поможет этот небольшой мануал.
Скрытый текст
If you are requested by support to reinstall your DAX drivers, please use the procedure below.This procedure assumes you are running on a 64-bit operating system. If you are using a 32-bit version of Windows, you will need to change the directory path to replace 64-bit Drivers with 32-bit Drivers.
In the example below SmartSDR is version 1.6.21 is used. Make certain you are running this procedure from the latest SmartSDR for Windows application folder installed on your PC.
- Shut down SmartSDR
- Close the DAX Control Panel
- Close any sound card applications that may be using a DAX sound device
- Using the Windows Search, type in CMD.
- Right lick on cmd.exe and Run as Administrator
- Change directory to where the DAX_IQ driver is located:cd \Program Files\FlexRadio Systems\SmartSDR v**\64-bit Drivers\IQ_DAX
- Run the DAXIQ driver uninstall batch file: SmartSDR_IQ_DAX_uninstall.bat
- Run the DAXIQ driver install batch file: SmartSDR_IQ_DAX_install.bat
- Change directory to where the RXAudio_DAX driver is located: cd \Program Files\FlexRadio Systems\SmartSDR v**\64-bit Drivers\RXAudio_DAX
- Run the RXAudio_DAX driver uninstall batch file: SmartSDR_RXAudio_DAX_uninstall.bat
- Run the RXAudio_DAX driver install batch file: SmartSDR_RXAudio_DAX_install.bat
- Change directory to where the TXAudio_DAX driver is located: cd \Program Files\FlexRadio Systems\SmartSDR v**\64-bit Drivers\TXAudio_DAX
- Run the TXAudio_DAX driver uninstall batch file: SmartSDR_TX_DAX_uninstall.bat
- Run the TXAudio_DAX driver install batch file: SmartSDR_TX_DAX_install.bat
- Change directory to where the MICAudio_DAX driver is located: cd \Program Files\FlexRadio Systems\SmartSDR v**\64-bit Drivers\MICAudio_DAX
- Run the MICAudio_DAX driver uninstall batch file: SmartSDR_MICAUDIO_DAX_uninstall.bat
- Run the TXAudio_DAX driver install batch file: SmartSDR_MICAUDIO_DAX_install.bat
- Close the command window
- Reboot the PC
Не надо грязи , просто не всегда надо давить кнопку YES а читать, что предлагает выбрать деинсталлятор
Всё работает чётко, проверено сотнями инсталляций и деинсталляций, без переустановок ОС.
Начинал с WIN7 и первых SSDR, потом проапгрейдил WIn7 до WIN10 и вчера проапгрейдил до Creators version с удалением и установкой SSDR - всё без проблем
P.S. работаю на МАС, с Parallels и Win10 - если интересует опыт виртуальной среды
Добавлено через 5 минут(ы):
можно и проще - перезагрузиться, установить заново полностью SSDR и ПРАВИЛЬНО деинсталлировать
Последний раз редактировалось R5AU; 16.06.2017 в 15:43.
Для тех, кто применяет удаленную работу F-6XXX.
http://www.ip-sens.com/ips2222.html
Интересуется народ, когда же SSDR v2.x.x?
Не уж-то и правда к концу месяца.
Тим ответил что намечено на июнь , но точная дата после полного тестирования
Спасибо от Георгий Назаров
Хм-м... Сколько интересного ждет впереди.
Не выпуск а продажа, их наклепали уже достаточно.
Для активации софта аппарат должен достучаться сам до их лицензионного
сервера.
Вот бы Флексы "встроили" Scope c такими функциями какLP-500 / LP-700 Digital Station Monitorв SmartSDR.
Эту тему просматривают: 6 (пользователей: 0 , гостей: 6)
