ага совершенно по нулям и на прием и на передачу. Видимо uart роутера чудит. Буду проверять. Все по цепочке.
Я не ставил, поэтому скорее нет!
Поставил!
Последний раз редактировалось R2DNB; 08.05.2015 в 22:06.
root@OpenWrt:~# aprx -dd
interface_store() aif->callsign = 'APRSIS'
/etc/aprx.conf:0: MYCALL = 'UB4AAD-10' ''
/etc/aprx.conf:3: INFO: SERVER = 'russia.aprs2.net':' 14580'
/etc/aprx.conf:4: INFO: FILTER = 'm/100' --> 'm/100'
/etc/aprx.conf:8: INFO: PIDFILE = '/var/run/aprx.pid' ''
/etc/aprx.conf:9: INFO: RFLOG = '/var/log/aprx/aprx-rf.log' ''
/etc/aprx.conf:10: INFO: APRXLOG = '/var/log/aprx/aprx.log' ''
/etc/aprx.conf:11: INFO: ERLANGFILE = '/var/run/aprx.state' ''
.. new style serial: '/dev/ttyATH0' '9600 8n1 KISS'.. tncid=0
.. param='9600' .. param='8n1' .. param='kiss'
callsign= 'UB4AAD-10'
interface_store() aif->callsign = 'UB4AAD-10'
Beacon cycle size: 15.00
BEACON parameters: symbol '/y' lat '5554.72N' lon '03652.89E' comment 'APRS GATE
ISTRA WELCOME AND 73! RX/TX 144.800 MHz'
/etc/aprx.conf:26 Lacking 'interface' keyword for this beacon definition. Beacon
ing to all Tx capable interfaces + APRSIS (mode depending)
RF+NET BEACON FOR ***>APRX20' '!5554.72N/03652.89EyAPRS GATE ISTRA WELCOME AND
/etc/aprx.conf:50 <source> source = 'APRSIS'
.. source_aif = 0x4254fc
viscous-delay = 5
via-path 'WIDE1-1'
.. OK filter b/RW3DKE/UB4AAD/MOXER
.. OK filter -b/RR6
.. <source> definition returning 0x4e80e0
<digipeater> sourcecount=1
1431112001 TTY /dev/ttyATH0 OPEN - fd=4 - OK
1431112001 << russia.aprs2.net:145 80 << user UB4AAD-10 pass 21765 vers aprx
2.00 filter m/100
1431112001 << russia.aprs2.net:145 80 >> # javAPRSSrvr 3.15b08
1431112001 << russia.aprs2.net:145 80 >> # logresp UB4AAD-10 verified, serve
r T2RUSSIA, adjunct "filter m/100" OK - Filter definition updated
1431112002 << russia.aprs2.net:145 80 >> UB3AAZ-14>APU25N,TCPIP*,qAC ,T2SWEDE
N2:=5547.54N/03748.76E&G/- R-I H24 Moscow, Victor 14.103
.. igate from aprsis
interface_receive_3r dparty() aif=0x4254fc, aif->digicount=1
tnc2addr = UB4AAD-10>APRX20,WIDE1-1
pbuf_alloc(112,114) -> 0x4dc098
parse_aprs_uncompres sed position ok: lat 55.792 lng 37.813
.. parse_aprs() rc=OK srcif=APRSIS tnc2addr='UB4AAD-10>APRX20,WIDE1-1' info_st
art='}UB3AAZ-14>APU25N,TCPIP*,UB4 AAD-10*:=5547.54N/03748.76E&G/- R-I H24 Moscow,
Victor 14.103'
pbuf_free(0x4dc098)
1431112006 Read timeout on /dev/ttyATH0; 2 seconds w/o input. fd=4
1431112022 << russia.aprs2.net:145 80 >> # javAPRSSrvr 3.15b08 8 May 2015 19
:08:58 GMT T2RUSSIA 194.186.45.251:14580 Please use port 14580 for all of your c
onnections - thanks!
beacons cycle: 15.00 minutes, increment: 15.00 minutes
beacons offset: 14.93 minutes
BEACON: idx=0, nexttime= +896 sec
1431112031 Now beaconing to interface UB4AAD-10 'UB4AAD-10>APRX20' -> '!555
4.72N/03652.89EyAPRS GATE ISTRA WELCOME AND 73! RX/TX 144.800 MHz', next beacon
in 14.93 minutes
interface_transmit_b eacon() aif=0x4e5e40, aif->txok=1 aif->callsign='UB4AAD-10'
interface_transmit_a x25(aif=0x4e5e40[UB4AAD-10], .., axlen=85)
kiss_kisswrite(->UB4AAD-10, axlen=85)erlang_add( UB4AAD-10, TX, 85, 1)
.. put 88 bytes of KISS frame on IO buffer
1431112031 << russia.aprs2.net:145 80 << UB4AAD-10>APRX20,qAR,UB4AAD-10:!555
1431112034 << russia.aprs2.net:145 80 >> R2DFR-L>APWW10,TCPIP*,qAC, T2RUSSIA:
>KO85qrE0 R2DFR-MIHAIL-QSO-MOSCOW
pbuf_alloc(90,92) -> 0x4dc098
А конфиг покажите. Пароль только не "палите", и в логе прибейте *****
mycall UB4AAD-10
<aprsis>
server russia.aprs2.net 14580
filter "m/100"
</aprsis>
<logging>
pidfile /var/run/aprx.pid
rflog /var/log/aprx/aprx-rf.log
aprxlog /var/log/aprx/aprx.log
erlangfile /var/run/aprx.state
</logging>
<interface>
serial-device /dev/ttyATH0 9600 8n1 KISS
initstring "\x0dINTFACE KISS\x0dRESET\x0d"
callsign $mycall
tx-ok true
# initstring "\x0dINTFACE KISS\x0dRESET\x0d"
timeout 3s
</interface>
<beacon>
beaconmode both
cycle-size 15m
beacon symbol "/y" lat "5554.72N" lon "03652.89E" comment "APRS GATE ISTRA WELCOME AND 73! RX/TX 144.800 MHz"
</beacon>
# *********** <telemetry> definition(s) follow *********
# The system will always send telemetry for all of its interfaces
# to APRSIS, but there is an option to define telemetry to be sent
# to radio channel by using following sections for each transmitter
# that is wanted to send out the telemetry.
# transmitter - callsign referring to <interface>
# via - optional via-path, only 1 callsign!
# source - one or more of <interface> callsigns for which
# the telemetry transmission is wanted for
#<telemetry>
# transmitter $mycall
# via TRACE1-1
# source $mycall
#</telemetry>
<digipeater>
transmitter $mycall
<source>
source APRSIS
relay-type third-party
viscous-delay 5
via-path WIDE1-1
filter -b/RR6
</source>
</digipeater>
Модем достаточно раз только в KISS перевести, в конфиг можно не добавлять инит модема , от логирования смысла не вижу можно смело прибить, а фильтрацию можно и потом настроить когда всё заработает. Для работы с файлами в роутере используйте WinSCP, с ним удобней
mycall UB4AAD-10
<aprsis>
filter "m/100"
</aprsis>
<interface>
serial-device /dev/ATH0 9600 8n1 KISS
callsign $mycall
tx-ok true
</interface>
<beacon>
beaconmode both
cycle-size 14m19s
</beacon>
<digipeater>
transmitter $mycall
<source>
source $mycall
relay-type digipeated
</source>
</digipeater>
Спасибо от R2DNB
Я уже с vi так натренировался!
Поправил как посоветовали! Тишина в обе стороны! Наверно уже утром буду дальше разбираться! Спасибо за помошь!
Завтра надеюсь все таки ПОБЕДИТЬ...
Спасибо от RA4FHE
