Показано с 1 по 4 из 4
Тема: Преселектор Heros SCR Preselector-CAT. Результаты измерений и первые впечатления
    Поделюсь впечатлениями о продукте, представленном здесь - http://herostechnology.co.uk/pages/SCR_Preselector.html
    Вот краткое изложение основных параметров (на сайте чуть подробнее):
    - Six selectable bands and preselector By-Pass.
    - Five Tuneable Band Pass Filter bank for HF Bands covering 1.8 to 30 MHz plus 50MHz band BPF.
    - All filters are LC passive. No active switching or amplifier devices in the signal path, (LNA Off), therefore it does not contribute to IMD (Intermodulation Distortion).
    - PTT feature enables connecting in-line with a 100Watts transceiver allowing to by-pass the preselector in transmission.
    - Two antenna inputs and one antenna output lets insert a converter, filter, etc between the antenna and the Preselector.
    - 0dB, 6dB, 12dB, 18dB input attenuator using MiniCircuits PAT series dedicated attenuation cells.
    - Embedded -110dB stop band Broadcast MW Band Rejection Filter.
    - Six Band Pass Filters.
    - Tuning coils wound on large toroid cores T-106 size, rated for 100Watts RF applications, avoiding saturation in front of large signals.
    - Band Pass Filters have Notch filters centered on the adjacent amateur bands giving an exceptional stop-band attenuation.
    - Digital tuning. Nine bits variable digital capacitor. One pF resolution. (Variable capacitor emulator).
    - Two embedded 7th order, 60MHz, Elliptic Low Pas Filter for FM broadcast band rejection and sampling frequency attenuation.
    - Switchable low noise amplifier (LNA). 25dB Gain, 38dB IP3, 2.7dB Noise Figure.
    - 12V DC/1Amp DC max. output connector for an external 150 Watts RF rating Input/Output by-pass dual power relay. (PTT or Keying line activated).
    - Power supply: 12Volts DC/ 0.5Amp max. 2.5mm plug power connector.
    - Dimension: 220mm x 165mm x 52mm (8.661 x 6.496 x 2.047in).
    - Weight: 1.5Kg.
    Начну с программного обеспечения. Оно отвратительно и бездарно. Видно, что программист на фирме один и он самоучка. Программа установки не требует, запускается сразу. Запустил, появилось какое-то окошко и быстро исчезло. Попробовал управлять, кнопки работают, как-бы аттенюатор переключается, предусилитель, частота перестраивается (правда, прямой ввод частоты не сделали в основном меню, хотя окошко программы занимает малую часть экрана, можно было бы увеличить окно и все функции вывести легко, видимо, человек как писал под мониторы 640 на 480 и 16 цветов, так и пишет). Только вот анализатор спектра показывает, что на самом деле ничего не происходит. В общем, не работает аппарат по всем признакам.
    Но на самом деле просто нужны драйвера, и при запуске быстро исчезнувшее окно сообщало об отсутствующем подключении. Вопрос – почему только эта надпись так быстро исчезает (будто аппарат обнаружен и проблема исчезла), а оболочка ведет себя так, будто все команды исполняются.
    Попробовал поставить драйвер – не ставится, т.к. нет цифровой подписи. Почитал описание в папке с драйвером – эти ребята не сделали цифровую подпись и предлагают для windows 8 отключить проверку цифровой подписи (в инструкции - http://herostechnology.co.uk/pdf/SCR...manual_web.pdf - этот момент также описан). Приведена пошаговая инструкция:
    By default Windows 8 enforces driver signatures (covert taxation); to disable it:
    From the Metro or Desktop
    Bring up mouse over to the right of the screen
    Go to Settings
    Change PC Settings
    General
    Advanced Start-up > Restart Now
    Trouble shoot
    Advanced options
    Start-up Settings
    Restart
    New Blue Window: Start-up Settings/ 'Disable driver signature enforcement"/ press F7
    Reboot
    Install the relevant driver, allowing the non signed driver message to install.
    Хорошо, уровень их единственного программиста уже давно ясен, отключаю защиту. Но винда все равно не принимает драйвер.
    Ладно, преодолевая психоделическое меню, попадаю в режим местного управления преселектором. И вот здесь ждет основное разочарование.
    Как Вам такая вот АЧХ:
    Это верхний для КВ поддиапазон.
    Если выбрать диапазон пониже (кажется, от 9 до 15 МГц), то ситуация лучше:
    Поддиапазоны частично перекрываются, но по краям диапазона потери в полосе пропускания выше. Это видно на картинках в архиве:
    http://www.cqham.ru/forum/attachment...1&d=1402057474
    Остается посмотреть интермодуляцию и шумы. Избирательность пока не впечатлила.
    Аватар для R2AGG
    Москва
    1,136
    6
    R2AGG
    Спасибо за мнение!
    Как раз проскочила информация по этой железке. Однако цена более 500 английских денег за такое, уже неинтересно!
    Посмотрел на одной частоте – 12500 кГц – вносимое в полосе пропускания затухание и выигрыш по чувствительности за счет встроенного LNA.
    Улучшение чувствительности наблюдал на WR-G31DDC (у него нет дополнительного LNA, как в 33-ей модели). В качестве генератора трудился SMB100A.
    Вносимое затухание преселектора в полосе пропускания оказалось около 1 дБ.
    Усиление преселектора в положении LNA ON составило 21 дБ.
    Мощность шума WR-G31DDC с отключенным аттенюатором в полосе 3 кГц составила минус 122 dBm. Чувствительность без преселектора при соотношении (сигнал+шум)/шум равном 20 дБ составила в указанной полосе минус 103 dBm.
    Включение преселектора с LNA в положении «ON» позволило поднять чувствительность до минус 112 dBm.
    Последний раз редактировалось R9MAB; 16.06.2014 в 20:18.
  4. Спасибо от UR5VFT
  5. #4
    Аватар для UA3VBD
    г.Юрьев-Польский
    1,255
    UA3VBD (ex UW3WO)
    Ещё один преселектор Tiny CAT SCR Preselector - https://herostechnology.co.uk/pages/...eselector.html
    ( сайт в переводе - https://translate.google.ru/translat...ml&prev=search )
ID:	283941   Нажмите на изображение для увеличения.
ID:	283942   Нажмите на изображение для увеличения.
Название:	Tiny-CAT SCR Preselector - схема.jpg
ID:	283944   Нажмите на изображение для увеличения.
Название:	Tiny-CAT SCR Preselector - USB модуль.jpg
ID:	283945   Нажмите на изображение для увеличения.
ID:	283947   Нажмите на изображение для увеличения.
ID:	283948   Нажмите на изображение для увеличения.
    Последний раз редактировалось UA3VBD; 06.03.2018 в 13:06.
    73! Юрий UA3VBD (ex UW3WO), RDA:VL-28, QTH Loc:KO96UL, RCFA:UA-00370
  1. Ответов: 80
    Последнее сообщение: 22.12.2020, 20:24
  2. Первые впечатления от импульсного источника питания S350-15
    от Палыч в разделе Источники питания
    Ответов: 173
    Последнее сообщение: 13.09.2015, 13:44
  3. SCR-522 и РСИУ-3
    от Валерий, RA3CC в разделе Старое радио (Ламповые души)
    Последнее сообщение: 12.06.2011, 15:56
  4. Впечатления о Р-376
    от us4lta в разделе Старое радио (Ламповые души)
    Последнее сообщение: 21.04.2011, 19:35
  5. Результаты по смесителю Брагина от PA3AKE
    от ve3ivm в разделе Технический кабинет
    Ответов: 375
    Последнее сообщение: 19.02.2010, 09:10
