Показано с 1 по 8 из 8
Тема: Direct Conversion HF Transceiver - VK3AJG
    По теме,ТПП!
    New mixer design
    По теме,ТПП!
    New mixer design
    А чего в нем для нас new?
    Александp, Belrig.by
    Hello SDR OMs,
    I tested exactly the same schematics last year with minor differences . This is substitute for original schematics in SDR1000 with FST3253 IC. I was disappointed with results upper limit was only 10-11 MHz at 14 MHz this schematics was working very bad. My design with 74HC4066 and 74HC4053 are working much better and upper limit is over 35 MHz!!!
    www.qsl.net/yu1lm
    www.yu1lm.qrpradio.com
    VY 73/72 GL in SDR home brew Tasa YU1LM/QRP Hello SDR OMs,
    Странно, у меня на 25 МГц все нормально было. Чем вызвано ограничение? Потерей чувствительности или подавления БП?
    Hello Alex,
    1. First at 14 MHz sensitivity was 2 dB worse than on 10 MHz or 3 dB worse than on 7 Mhz. At 21 MHz I lost more than 10 dB in sensitivity (I used 330 Ohm resistor instead 220 after detector) .
    2. In TX part balancing was about 45-50 DB at 7 MHz than 25 DB at 14 MHz . At 21 MHz balancing was going down to only 15 dB( Output swing for OP AMP TL084...for 100 load at output is big problem high distortions. Min R load for good compromise is about 270-330 Ohms output swing 9 Vp-p )
    3. When I made my SDR RX DR1 with 74HC4052 it was really disaster (DC coupled connection) AT 14 MHz sensitivity was down 10 DB at 21 MHZ 30 db!!!! Some switheches was ON when time was OFF and vice versa and that was the reason for bad performances.
    Извиняюсь, я решил, что Вы на FST3253 получили такое безобразие. А речь все же о 4052 как в оригинале.
    У меня 3253, с ней все ОК
    73!
    Неужели такая разница из-за микросхемы??
    Резонанс где-то рядом!
    Hi;
    I put some links yesterday on this site and my links came up repeated. I requested the site's admin to correct the issue by removing the duplicates, however he removed all my links.
    Additionaly,my booss ......I will try later
  1. HF/VHF Transceiver PT-8000A
    от Чапай в разделе Трансиверы, приемники КВ/УКВ
    Ответов: 219
    Последнее сообщение: 26.10.2022, 17:54
  2. ELECRAFT K3 Transceiver #2
    от UA6AP в разделе Elecraft
    Ответов: 530
    Последнее сообщение: 13.04.2015, 11:10
  3. FT-808 HF Transceiver
    от Alex2003 в разделе Yaesu
    Последнее сообщение: 25.11.2009, 20:02
  4. QRPP Transceiver PSK-20m RA4ABU
    от gromoboy в разделе Для любителей QRP и QRPP
    Ответов: 14
    Последнее сообщение: 09.09.2009, 11:15
  5. ATmega8 + PDIUSBD12 achieve USB-232 conversion
    от Genadi Zawidowski в разделе Конструкции на микроконтроллерах для радиолюбителей
    Последнее сообщение: 12.02.2008, 00:52
