Страница 31 из 39 ПерваяПервая ... 2128293031323334 ... ПоследняяПоследняя
Показано с 301 по 310 из 382
Тема: Трансивер KENWOOD TS-590SG
  1. #301
    Аватар для UA3VBD
    г.Юрьев-Польский
    1,255
    UA3VBD (ex UW3WO)
    Версия Virtual COM Port Driver - CP210x USB to UART Bridge Driver v6.7.4 - January 18, 2017
    http://www.silabs.com/products/devel...ge-vcp-drivers
    "CP210x Windows Driver Revision History
    version 6.7.4 (DriverVer=09/19/2016,6.7.4.261)
    New features/Enhancements
    Device Guard compliant
    CP210XFW-747: Add 3 new parallel PIDs one each for the single-, dual- & quad-port CP210x devices (to be distributed via Windows Update)
    CP210XFW-741: Fix driver to use correct interface string index for the multi-interface CP210x devices (CP2105 & CP2108). Return iProduct string for other CP210x devices.
    CP210XFW-713: Add protection against IRP_MJ_CLOSE coming before IRP_MJ_CLEANUP. In such case EvtFileCleanup callback was called with 0 FileObject, causeing a crash.
    Serenum is suspected of causing this, even though there is no proof except that it's present, was introduced recently and this crash was never registered before.
    CP210XFW-691: Fixed race between timer activation and request cancelation during processing of read rwquests.
    Changed raw WDF read request timer to our wrapper.
    CP210XFW-693: bugfix: WMI command "wmic path Win32_SerialPort get Availability^, DeviceID^, Name" is unable to enumerate the port.
    CP210XFW-686: EvtRequestCancel for wait mask IRP crashed because the request was already completed. It didn't serialize well with other places that can complete it.
    It looked like XOff IRP may have the same proble. This patch is adding an extra check into *all* other EvtRequestCancel functions to make sure this doesn't happen again.
    Changed IOCTLs returning polled-cached MDMSTS to explicitly read the status. Use reg value DisableHwAccessInMod emStatusIoctls to revert this new functionality to old behavior.
    Improved debug prints.
    SerialDbgPrintEx used 1K of stack for the string, reduced to 256.
    Resolved many static Code Analysis warnings
    Added accounting for data in chip's TX queue. Added translation of COMM_STATUS::ulError s into SERIAL_EV_BREAK and SERIAL_EV_ERR.
    CP210XFW-549, CP210XFW-536, CP210XFW-546: Generate events for IOCTL_SERIAL_SET_WAI T_MASK from COMM_STATUS::ulError s. Can be disabled by DisableCommStatusPol ling reg value.
    Added spinlock around ModemStatus change detection. Refactored modem status event signalling to use common function.
    Move passive level functions into the paged section.
    MCUFW-740: Made device close operation wait for chip's Tx queue to empty. Added registry settings DisableTxEmptyCheckI nClose and TxEmptyTimeoutOnClos eInMs.
    Improve control transfer debug prints and clean up code, otherwise no functional changes.
    MCUFW-740: Fixed EV_TXEMPTY to account for bytes in chip's Tx queue.
    MCUFW-740: New functions to sync access to comm error storage from multiple threads.
    Added DisableTxEmptyCheckI nGetCommStatusIoctl reg value.
    Refactor control request I/O. MCUFW-740: Fixed IOCTL_SERIAL_GET_COM MSTATUS.
    CP210XFW-648: Set a three second timeout on WdfUsbTargetDeviceSe ndControlTransferSyn chronously(). "
    Последний раз редактировалось UA3VBD; 04.05.2017 в 09:23.
    73! Юрий UA3VBD (ex UW3WO), RDA:VL-28, QTH Loc:KO96UL, RCFA:UA-00370
  2. #302
    Подскажите пожалуйста как подключить трансивер к компьютеру чтобы работать из программы на передачу в телеграфе. Через один USB шнур все работает кроме передачи.
  3. #303
    Использовать второй шнур для СОМ порта в трансивере. Если СОМ порта в компе нет, то сделать переходник USB/СОМ, например на MAX 232 или других аналогах.
    http://dl2kq.de/trx/2-13.htm
    Только шнурок хороший постарайтесь найти, а то подвисания, нестыковка и прочие "бока" вылезут. Можете сами сделать, только, опять же, постарайтесь хороший экранированный шнур для него найти или сами сделайте. А то китайские "три волосины" думаю знаете.
    Ну или внешний интерфейс использовать.
    З.Ы. В соседней теме эта проблема подробно описана:
    http://www.cqham.ru/forum/showthread...590S-3/page145
    Последний раз редактировалось UR7EY; 04.06.2017 в 13:08.
    73! Анатолий
  4. #304
    Можно и без доп. шнура, но придется поработать скальпелем и паяльником:
    http://forum.qrz.ru/264-ts-590/29765...ml#post1001352
  5. #305
    Аватар для UA3VBD
    г.Юрьев-Польский
    1,255
    UA3VBD (ex UW3WO)
    В Радиоэксперте появился русский перевод "Руководства пользователя трансивера KENWOOD TS-590SG".
    Сегодня получил почтовой бандеролью, спасибо за выполнение своих обещаний.
  6. #306
    Ради любопытства зашел на сайт, там только 590S.
    Ссылочку пожалуйста приведите. Может не там смотрю..
  7. #307
    Аватар для UA3VBD
    г.Юрьев-Польский
    1,255
    UA3VBD (ex UW3WO)
    Информация об этом на сайте пока отсутствует. Общался с операторами-онлайн.
  8. #308
    Аватар для UA3VBD
    г.Юрьев-Польский
    1,255
    UA3VBD (ex UW3WO)
    Пока информация о "Руководстве пользователя трансивера TS-590SG" на сайте Радиоэксперта отсутствует.
    Online - консультант магазина сообщил, что приобрести инструкцию можно сделав заказ инструкции для TS-590S, указав в заказе, что нужна инструкция для TS-590SG.
Название:	титульный лист инструкции TS-590SG.jpg
    Последний раз редактировалось UA3VBD; 29.08.2017 в 11:45.
  9. #309
    Аватар для radio-22
    г. Мелитополь
    79
    US1QA
    Можно ли, в ts-590sg при помощи SDRuno осуществить не только панораму, но и двойной прием ( сплит,крос) как в ts-990 ft-1000 ?
    C уважением.
    Борис.
  10. #310
    Аватар для UA3VBD
    г.Юрьев-Польский
    1,255
    UA3VBD (ex UW3WO)
    Вышло обновление драйвера виртуального порта Virtual COM Port Driver - RELEASE NOTES FOR 6.7.5 (2017-10-13) -
    CP210x_Windows_Drive rs.zip
    https://www.silabs.com/products/deve...ge-vcp-drivers
    Последний раз редактировалось UA3VBD; 27.11.2017 в 05:52.
  1. Трансивер KENWOOD TS-2000
    от ab294 в разделе TS-2000
    Ответов: 3399
    Последнее сообщение: 14.12.2023, 12:29
  2. трансивер KENWOOD-570D
    от uu1jj в разделе TS-570
    Ответов: 118
    Последнее сообщение: 25.02.2023, 18:03
  3. Трансивер KENWOOD TS-590S #2
    от RU9CA в разделе TS-590
    Ответов: 1234
    Последнее сообщение: 19.11.2013, 22:20
  4. Трансивер Kenwood TM733A помогите с ремонтом
    от wsthdd в разделе Технический кабинет
    Последнее сообщение: 25.06.2013, 18:54
  5. Трансивер KENWOOD TS-590S
    от R7KK в разделе TS-590
    Ответов: 4550
    Последнее сообщение: 24.02.2012, 19:22
