Страница 2 из 6 ПерваяПервая 12345 ... ПоследняяПоследняя
Показано с 11 по 20 из 51
Тема: IC-706.Помогите распаковать на передачу!
    Enables out-of-band transmit for 1.6 MHz to 54 MHz. This does not enable extended VHF transmit This does not enable AM or FM broadcast band transmit.
    Your memories will be cleared after this modification, since you need to reset the CPU.
    Open the top of the radio by removing the 3 top screws and 2 side screws. Look at the radio with the front panel facing you.
    Gently pull up the speaker and set is aside without damaging the speaker or the wires that attach it to the rig.
    Note the silver rectangular box near the middle of the PCB marked something like "9 MHz SSB Filter".
    Move your eyes up from this filter toward the back of the radio. Just before you get to the "D 108" marking, you will see two tiny diodes, two blank spaces, and one additional diode. They look something like this:
    D105
    --D108-- [ ]
    [XX] [XX] [ ] [ ] [XX]
    D60 D59 D58 D57 D72
    Remove this diode ^^^^
    D60 USA low power 50 MHz (remove for 100 W output power)
    D59 CPU Tx limit
    D58 Eur Fra 144-146 MHz
    D57 Den Fra 50 MHz
    D72 unknown
    D105 unknown
    Note: French versions have diode D84 (parallel with D59) and D85 on the underside of this print.
    D D
    8 8
    4 5
    9 1
    |IC10 | TD62783AF
    10 18
    D84 CPU Tx limit
    D85 Fra HF band
    The second diode from the left needs to be removed. I did this by crushing it with long-nosed pliers. You can also heat it with a low-wattage soldering iron and pull it up with tweezers. Be sure not to damage the other diodes or the PCB. Be sure that you don't apply too much heat, since the heat can damage the PCB and the other diodes.
    Re-assemble the radio. Reset the CPU by pressing and holding down the UP and DOWN buttons on the front panel and pressing POWER.
    This article has been read 19276 times. Это из сайта переведёте будет всё ок.
    D105
    --D108-- [ ]
    D60 D59 D58 D57 D72
    D59 CPU Tx limit
    D57 Den Fra 50 MHz
    D72 unknown
    D105 unknown
    D D
    8 8
    4 5
    9 1
    |IC10 | TD62783AF
    10 18
    D84 CPU Tx limit
    D85 Fra HF band
    Спасибо .
    Завтра открою трансивер - по пробую .
    Если не секрет , где лежит оригинал .
    Может еще что есть , все ж станция для японского рынка.
    PS в сообщении Вашем по моему повтор.
    С Уважением Алексей!
    г.Киров
    278
    ex-RW4NX
    IC-706 на СВ на передачу НЕОТКРЫВАЕТСЯ.Аппара т НЕмучайте.
  4. #14
    Аватар для RU3DUC
    KO95AO
    386
    RU3DUC
    706 на СВ на передачу РАБОТАЕТ! ( у меня правда американская версия) что делали - не знаю, купил уже раскрытый
  5. #15
    А кто с этим спорит? На mods.dk - исчерпывающая информация о "раскрытии" американских и европейских версий.
    Но речь идет об
    Цитата Сообщение от Lainer Посмотреть сообщение
    IC-706MKII (в треугольнике стоит индекс J)
    Этот значок означает, что аппарат был выпущен для использования в Японии. У них более жесткие требования по "обеспечению нераскрываемости".
    Андрей
  6. #16
    в общем я думаю что завеса запрета потихоньку при откроется
    если мне в этом кто нить поможет .
    что для этого требуется
    Посмотрев внимательно схемы , от обоих аппаратов пришел к выводу - что аппараты очень похожи по организации , по схенематике разница существенная . Но все ж . Прошу тех - у кого есть в работе IC-706MK2 , которые не японец , а сделан для Европы , Америки - и чтобы человек дружил с паяльником и программаторами. Открыть трансивер (верхняя крышка), отключаем динамик, валкодером и к себе смотрим внимательно. В правом верхнем углу на плате MAIN BOARD (куда фильтра вставляются) есть микросхема памяти Х25320. Аккуратно выпаять ее оттуда и прочитать. Я думаю что в этой еепромке и хранятся данные о статусе диапазонов. Что где можно , а что нет.
    За ранее благодарен .
    Думаю что будет всем интересно и главное нужно !
  7. #17
    В нашем городе было два таких трансивера ни один раскрыть не удалось.
  8. #18
    а то что я ваше описал - делали ?
    после замены прошивки Reset делали ?
  9. #19
    Краснодарский кр.
    251
    Lainer, Чтото мне подсказывает , что никто выпаивать из своих аппаратов ничего не будет, в угоду комуто...У меня 706мк2ж-американец-раскрыт .На передачу от1 до199 и от415 до490. По поводу японских версий оч. глубокие сомнения ...
    Когда под рукой нет ничего , кроме молотка-всё вокруг кажется гвоздями...
  10. #20
    Если человеку глубоко наплевать на проблему просящего помощи - то да ,
    или просто побоится чего либо делать, то да - согласен на все 100% .
    Такой или просто будет молчать , или флудить не по теме .
    Если же человеку всеж интересно , что и как и почему - то он на верняка поможет .
    Да и собсно не я один такой с таким трансивером.
    Один рискнул - второй помог - если ОК то помогли всем !
    а вот у меня нет и я хочу по пробовать - рискнуть , если что - то проц на запас знаю где есть .
    и стоит он не таких уж огромных денег.
    Последний раз редактировалось Lainer; 03.03.2011 в 18:39.
  1. Помогите раскрыть icom-726 на передачу *MADE IN JAPAN*
    от RA9LE в разделе Трансиверы, приемники КВ/УКВ
    Ответов: 25
    Последнее сообщение: 16.01.2020, 01:58
  2. ПОМОГИТЕ раскрыть на передачу KENWOOD TH-78
    от REGION86 в разделе Модификация радиостанций
    Последнее сообщение: 12.12.2010, 23:29
  3. Помогите запустить IC M710 на передачу в любительских диапа
    от Алексей_Сарженко в разделе Трансиверы, приемники КВ/УКВ
    Последнее сообщение: 25.12.2009, 19:06
  4. Раскрыть ICOM 7400 на передачу
    от Pulidze в разделе Технический кабинет
    Последнее сообщение: 22.09.2008, 12:22
  5. Помогите раскрыть icom-732 на передачу
    от СергейВысоцкий в разделе Трансиверы, приемники КВ/УКВ
    Последнее сообщение: 06.12.2007, 09:57
