Страница 7 из 13 ПерваяПервая ... 45678910 ... ПоследняяПоследняя
Показано с 61 по 70 из 130
Тема: Работа в APRS через программу JS8Call
  1. #61
    Обновление программы до версии 0.12
    Изменения:
    Bump to v0.12.0
    Added new status command output and fixed a bug in macros
    Added confirmation to clear all activity item
    Updated menu item label
    Moved callsign count to header instead of in the ALLCALL row since that row can be hidden now
    Restore clear all menu item label
    Performing some minimal code cleanup
    Changed status response to only report things that are 'on'
    Merge branch 'ft8call-develop' of bitbucket.org:widefi do/js8call-private into ft8call-develop
    Fixed macro expansion of macro QTC, QTH, CQ, REPLY values
    Fixed deselect callsign after logging not showing up in configuration
    Squashed commit of the following:
    Cleanup
    Updated suggestions menu to be inline
    Added a toggle to disable word suggestions
    Restore the alert box for when a message is received via relay
    Added timestamp to alert
    Display 0M idle status in status command
    Added HEARING short message back in to complement HEARING query
    Removed most old compat query shortcodes
    Renamed QUERY to QUERY CALL. Added generic user QUERY with no auto-reply (for scripting).
    Fixed #60: sort by menu added to right click of the table headers
    Added configuration parameter to execute an external command when PTT is toggled
    Fixed bug with hearing command response. Added status response shortcode.
    Added RIG.PTT status message to the API
    Bump eol
    Cleanup of build frames and a note for later
  2. Спасибо от DL8RCB
  3. #62
    Модератор Аватар для DL8RCB
    94157 Perlesreut
    16,247
    DL8RCB, ex UW9EZ
    Последний раз редактировалось DL8RCB; 22.02.2019 в 14:25.
  4. #63
    94157 Perlesreut
    16,247
    DL8RCB, ex UW9EZ
    The latest version of JS8Call is 1.0.0-rc1:
    So...what's new?
    • /P callsign suffix can now be transmitted in a single frame for all non-compound callsigns (meaning KN4CRD/P: JY1/P SNR? would transmit in one frame). Huzzah!
    • HB is now paused while you are "in QSO" (as in, when you have a callsign selected) and unpaused when you deselect your QSO partner.
    • If you open the message inbox without a callsign selected you will be able to view "All" messages.
    • You can now store a message at your local station for somebody else. Really helpful if you know that your QSO partner will be able to hear you later (i.e., you usually have a good propagation path) but you won't be around the rig at that time (maybe overnight?). Access this by right clicking on the Callsign and selecting "Store Message".
    • You can now add a custom interval for HB and CQ messages (up to 1440 minutes...i.e., once per day)
    • The "QTH?" command is now called "INFO?" which contains generic station information (antenna, rig, qth, power, anything).
    • There are now some pre-configured group names that can be transmitted in one frame (@JS8NET, @GROUP1, etc). Check the documentation for more!
    • HEARING messages now parse callsigns and add them to the callsign tooltips
    • Fixed a bunch of bugs related to printing of ACKs, sorting of frequencies, etc.
    Hi Folks!
    It's been a fun journey so far and I really appreciate all the help along the way. I'm happy to announce that our first 1.0 release candidate of JS8Call is ready for you to download: https://groups.io/g/js8call/wiki/Download-Links This release candidate will be good until March 11, after which I'm planning our 1.0 general release. There may be another release candidate with bug fixes in between, but the goal is that March 11 is our go-live date. Woohoo!
    MacOS:
    https://s3.amazonaws.com/js8call/1.0...rc1-Darwin.dmg
    Windows:
    https://s3.amazonaws.com/js8call/1.0...-rc1-win32.exe
    RaspberryPi:
    https://s3.amazonaws.com/js8call/1.0.0-rc1/js8call_1.0.0-rc1_armhf.deb
    Linux:
    https://s3.amazonaws.com/js8call/1.0...6.04_amd64.deb
    https://s3.amazonaws.com/js8call/1.0...8.04_amd64.deb
    https://s3.amazonaws.com/js8call/1.0...0-rc1_i386.deb
    https://s3.amazonaws.com/js8call/1.0...86_64.AppImage
    Последний раз редактировалось DL8RCB; 22.02.2019 в 14:46.
  5. Спасибо от RK1AT
  6. #64
    94157 Perlesreut
    16,247
    DL8RCB, ex UW9EZ
    Новая версия программы JS8Call
    Howdy Folks,
    Now I know I said last time that March 11 was the anticipated go-live date for the 1.0 release. Well, a few things snuck in there that I needed to iron out. So, here we go with 1.0 Release Candidate 2
    This release includes:
    • Fixed #76: added tone output to API
    • Fixed #135: query commands through relay. Changed the QUERY CALL reply format so as to not confuse folks with random ACKs.
    • Fixed & cleaned up empty dB formatting in the call and band activity tables.
    • Fixed #129: relays now use 'VIA' as the intermediate text for relay path computation instead of 'DE'.
    • Fixed also relays still being ACKed while relay messaging was disabled.
    • Added tooltip with absolute date for age columns
    • Added NACK command for future implementation
    • Added log details columns (worked before, name, and comment) to call activity table
    • Added DIT DIT short message
    I'm confident that April 1 will treat us all well this year Cheers y'all!
    Best,
    Jordan / KN4CRD
    _._,_._,_
    The latest version of JS8Call is 1.0.0-rc2:
    Source:
    git clone https://widefido@bitbucket.o rg/widefido/js8call.git
    MacOS:
    https://s3.amazonaws.com/js8call/1.0.0-rc2/js8call-1.0.0-rc2-Darwin.dmg
    Windows:
    https://s3.amazonaws.com/js8call/1.0.0-rc2/js8call-1.0.0-rc2-win32.exe
    RaspberryPi:
    https://s3.amazonaws.com/js8call/1.0.0-rc2/js8call_1.0.0-rc2_armhf.deb
    Linux:
    https://s3.amazonaws.com/js8call/1.0.0-rc2/js8call_1.0.0-rc2_16.04_amd64.deb
    https://s3.amazonaws.com/js8call/1.0.0-rc2/js8call_1.0.0-rc2_18.04_amd64.deb
    https://s3.amazonaws.com/js8call/1.0.0-rc2/js8call_1.0.0-rc2_i386.deb
    Fedora COPR:
    https://copr.fedorainfraclou d.org/coprs/hobbes1069/JS8Call/
    https://s3.amazonaws.com/js8call/1.0.0-rc2/js8call-v1.0.0-rc2-Linux-Desktop.x86_64.AppIm age
    Последний раз редактировалось DL8RCB; 12.03.2019 в 12:51.
  7. #65
  8. #66
    Аватар для RK1NA
    Петрозаводск
    3,694
    RK1NA
    программа в очередной раз обновилась
    Нынче уже есть версия 2.0.0.
    В АПРС есть активность?
  9. #67
    94157 Perlesreut
    16,247
    DL8RCB, ex UW9EZ
    если именно по этой программе?
    не в курсе, попытки призвать сообщество к работе и экспериментам результата не дали
  10. #68
    Аватар для RK1NA
    Петрозаводск
    3,694
    RK1NA
    Вот я пытаюсь. На 20-ке маяк нынче запущен.
  11. #69
    14103 LSB? Не слышу.
    73!
  12. #70
    94157 Perlesreut
    16,247
    DL8RCB, ex UW9EZ
    ну так это и прекрасно,спасибо информируйте в теме
    осталось уточнить под каким позывным бакен?
    у меня в автотрэке rk1na* не видит
    Последний раз редактировалось DL8RCB; 28.11.2019 в 13:22.
  1. работа форума APRS
    от DL8RCB в разделе APRS и другие виды пакетной связи
    Ответов: 82
    Последнее сообщение: 16.06.2016, 15:11
  2. Работа через дробь
    от RV3 в разделе Правовой практикум радиолюбителя
    Ответов: 137
    Последнее сообщение: 02.06.2014, 14:20
  3. Работа через PCSat2
    от K6VHF в разделе Программы для УКВ
    Последнее сообщение: 22.03.2011, 21:29
  4. Проги и их работа через прокси
    от Ferz в разделе Программное обеспечение
    Ответов: 55
    Последнее сообщение: 08.04.2008, 14:37
