День добрый!
Много читал про искажения сигнала в ssb, такой вопрос - в ft8 как передача? Заранее спасибо
Прошивка от Didier F5NPV с улучшением SSB. В архиве INO файл. Описание изменений позже.
Добавлено через 44 минут(ы):
Re: [µSDX] Audio Distortion on SSB
Didier F5NPV
QCX-SSB_102w_ssb_testing _mod.rar
Hello,
i have add new menu in the current 1.02w firmware in order to assist the SSB experimentation and also to provide the opportunity to modify some embedded features from the code without any needs to flash the ATMEGA each time you want to modify a setup.
The new menu are :
-CW sidetone level adjustment* --> this mod was implemented few weeks ago and currently working well*
-Mic attenuation in order to add 6db attenuation to the AF MIC level --> on/off (1/0)
-MORE_MIC_GAIN (Name MICBOOST) --> on/off (1/0)
-DIG_MODE --> on/off (1/0)
Accoring the test i add performed* when playing with all parameters in addtion with the TX DRIVE , you will notice some changes and may improve your SSB AF quality in some case . The best result for myself are :*
-Mic attenuation --> OFF therefore with ON the result are also not so bad at all*
-MORE_MIC_GAIN (Name MICBOOST) --> OFF*
-DIG_MODE --> OFF
Enclosed ,you will find the Custom 1.02w firmware and hope it will assist you guys during your test . Do not hesitate to comment or to suggest some other enhancement because since i am not at all a software guy , my coding skill is really fuzzy. Currently i do not notice any glitch or side effect with the modified firmware.
73s Didier
Последний раз редактировалось Vladimir-dl7pga; 27.11.2021 в 13:40.
Спасибо от noisefault, Сан Саныч
UD3SBV, можете показать, как Вы закрепили ПП Нано в корпусе, и если можно ссылку на корпус?
Didier, F5NPV продолжил совершенствовать SSB модус, добавил пункты меню. Я могу перенести сюда файл.
Кто зарегистрирован на groups.io, можете посмотреть и почитать:
https://groups.io/g/ucx/message/11850
Цитата:
Hello,
According your suggestion for MULTI_ADC, i add an additional menu in the Sketch in order to switch ON/OFF this feature.
Obviously this kind of modification will not really assist if you have serious issue with SSB distortion , therefore it can really assist if you just some little distortion or clipping in SSB mode. For fine tuning it is something to be considered.
This firmware modification can be oviously adjusted since some feature are intarcting with each other
So now we have the additional menu :
-MICBOOST1 --> MORE_MIC_GAIN --> ON or OFF
-MICBOOST2 --> MULTI_ADC --> ON or OFF
-MIC ATT --> MIC_ATTEN --> ON or OFF
-DIGIMODE --> DIG_MODE --> ON or OFF
-TONE VOL to setup your CW Sidetone volume
73s Didier
Конец цитаты:
Последний раз редактировалось Vladimir-dl7pga; 27.11.2021 в 22:14.
ЧТо там можно неправильно собрать? - вся схема на передачу один транзистор на выходе сишки и парочка RC цепочек.
Кто может сказать что здесь подавленна ненужная боковая полоса ? Ваще не ожидал подобное увидеть на сдр, поискал в инете , ан нет не у меня одного такая штука, видео не моё
Хриплость сигнала и прочие претензии к "басочкам" ваще не волнуют, но ненужная боковая на передачу не должна быть так загажена, подобного мусора даже близко ТПП Полякова на 160м с копеечным фазовращателем на RC цепочках не выдаёт.
Последний раз редактировалось SKirov; 27.11.2021 в 23:04.
Спасибо от RC3ZQ
SKirov, здравствуйте. Я могу сказать, что в собранном мной аппарате даже вблизи приёмной антенны sdr трансивера боковая совсем чуть чуть вылазит. Подозреваю, что у вас перегружен вход вашего RTL SDR свистка. Вот и панорама отсюда такая "жуткая". Для своей схемы и программного обеспечения этот трансивер отлично отрабатывает.
На видео прошивка 1.02w with the old receiver. Но это та же 1.02 w, только приёмная часть кода из 1.02j, на передачу не влияет.
https://youtu.be/PqEYYxwof_Y
