Показано с 1 по 5 из 5
Тема: Linear Sat Up_435/Down_145 SSB,CW
    Модератор Аватар для DL8RCB
    94157 Perlesreut
    16,252
    DL8RCB, ex UW9EZ
    1.
    JO-97 ( JY!Sat )
    Downlink 145.855-145.875 MHz (USB)
    Uplink 435.100-435.120 MHz. (LSB)
    The telemetry downlink frequency is 145.840 MHz, this will use the usual FUNcube standard 1k2 BPSK format. The linear transponder, for Single Sideband (SSB) and CW
    2.
    TO-108 (CAS-6)
    U/V Linear Transponder Downlink: 145.925 MHz
    U/V Linear Transponder Uplink: 435.280 MHz
    CW Telemetry Beacon: 145.910 MHz 17dBm
    AX.25 4.8k Baud GMSK Telemetry: 145.890 MHz 20dBm
    3.
    CAS-4A
    Linear transponder downlink 145.870 MHz,
    Linear transponder uplink 435.220 MHz
    emission designator 20K0V8WWF, output power 20 dBm
    CW telemetry beacon 145.855 MHz, emission designator 100HA1AAN, output power 17 dBm
    GMSK telemetry 145.835 MHz, emission designator 16K0F1DCN, output power 20 dBm
    4.
    CAS - 4B
    Linear transponder downlink 145.925 MHz
    Linear transponder uplink 435.280 MHz
    CW telemetry beacon 145.910 MHz, emission designator 100HA1AAN, output power 17 dBm
    GMSK telemetry 145.890 MHz, emission designator 16K0F1DCN, output power 20 dBm
    5.
    LUSEX (LO-87 / NUSat-1)
    uplink of 435.935 MHz to 435.965 MHz
    downlink of 145.935 MHz to 145.965 MHz
    Total power output is 250 mW.
    CW beacon at 145.900 MHz with a power output of 70 mW.
    6.
    EO-88 (FunCube on Nayif-1)
    435.045-435.015 MHz Uplink
    145.960-145.990 MHz Downlink
    • 145.940 MHz 1200 bps BPSK FUNcube beacon
    • 500 mW inverting SSB/CW linear transponder
    7.
    UVSQ-SAT
    LATMOS-01
    Uplink: 437.020 МГц
    Downlink: 145.905 МГц
    Telem. 437.020 МГц - G3RUH 9k6
    Для декодирования сообщений,вы можете использовать программное обеспечение декодера UVSQ-SAT, доступное по адресу: https://code.electrolab.fr/xtof/josa.../UserManual.md
    Beacon baud rate: 1200 bps and 9600 bps
    Beacon interval: 30 seconds
    Bandwidth: 20 kHz
    Modulati
    eon typ: BPSK
    Protocol: AX-25 framing
    Encoding: NRZI encoding and G3RUH scrambling
    8.
    CAS-3a
    - uplink: 435.040
    - downlink: 145.675
    -CW Beacon: 145.660
    9.
    CAS-3b
    - uplink: 435.090 to 435.110 LSB
    - downlink: 145.730 to 145.750 USB
    - CW beacon: 145.725
    - digital telemetry: 145.640
    10.
    AO-73 (FUNcube-1)
    - uplink: 435.130 to 435.150 LSB (435.140 MHz) ставим в орбитроне
    - downlink: 145.950 to 146.970 USB (145.960 MHz) ставим в орбитроне
    прямая ссылка на лог AO-73 _ http://aar29.free.fr/sat/ao73/logentry.php
    - CW beacon: 145.935
    - digital telemetry: 145.935
    Download FUNcube Telemetry Dashboard software
    Последний раз редактировалось DL8RCB; 19.04.2023 в 09:32.
    94157 Perlesreut
    16,252
    DL8RCB, ex UW9EZ
    3.
    CAS-4A
    Последний раз редактировалось DL8RCB; 05.04.2022 в 18:42.
    94157 Perlesreut
    16,252
    DL8RCB, ex UW9EZ
    Цитата Сообщение от DL8RCB Посмотреть сообщение
    4.
    CAS - 4B
    94157 Perlesreut
    16,252
    DL8RCB, ex UW9EZ
    1.
    JO-97 ( JY!Sat )
    94157 Perlesreut
    16,252
    DL8RCB, ex UW9EZ
    [quote="DL8RCB;177855 6"]3.
    CAS-4A
    Последний раз редактировалось DL8RCB; 12.06.2022 в 16:12.
  1. SAT с APRS
    от DL8RCB в разделе Различное применение APRS
    Ответов: 13
    Последнее сообщение: 29.01.2023, 13:03
  2. Cигнал со спутника ITUpSAT1
    от US1GBF в разделе SAT связи
    Ответов: 16
    Последнее сообщение: 04.06.2013, 17:17
  3. 1 кВт на УКВ, на новых транзисторах!
    от borman в разделе Усилители мощности
    Последнее сообщение: 07.05.2008, 13:44
  4. DX cluster со спутника и MixW2
    от alex74 в разделе Цифровые виды связи Новые технологии в электронике и связи
    Последнее сообщение: 18.10.2005, 18:44
