In file included from c:\arduino\sketchbook\libraries\bitluni_esp32lib\src\i2s\DMABufferDescriptor.h:13,
from c:\arduino\sketchbook\libraries\bitluni_esp32lib\src\i2s\i2s.h:23,
from C:\Arduino\Sketchbook\libraries\bitluni_ESP32Lib\src/VGA/VGA.h:14,
from C:\Arduino\Sketchbook\libraries\bitluni_ESP32Lib\src/VGA/VGA14BitI.h:13,
from C:\Arduino\Sketchbook\libraries\bitluni_ESP32Lib\src/ESP32Lib.h:3,
from C:\Arduino\Sketchbook\ESP32-SDR-TRX\ESP32-SDR-TRX.ino:8:
c:\arduino\sketchbook\libraries\bitluni_esp32lib\src\tools\log.h:16: warning: "DEBUG_PRINTLN" redefined
#define DEBUG_PRINTLN(a) Serial.println(a)
In file included from C:\Arduino\Sketchbook\ESP32-SDR-TRX\ESP32-SDR-TRX.ino:6:
C:\Arduino\Sketchbook\libraries\PCF8574_library/PCF8574.h:76: note: this is the location of the previous definition
#define DEBUG_PRINTLN(...) {}
c:\arduino\sketchbook\libraries\bitluni_esp32lib\src\tools\log.h:17: warning: "DEBUG_PRINT" redefined
#define DEBUG_PRINT(a) Serial.print(a)
C:\Arduino\Sketchbook\libraries\PCF8574_library/PCF8574.h:75: note: this is the location of the previous definition
#define DEBUG_PRINT(...) {}
In file included from C:\Arduino\Sketchbook\ESP32-SDR-TRX\ESP32-SDR-TRX.ino:15:
C:\Arduino\Sketchbook\ESP32-SDR-TRX\global.h:98: warning: "B0" redefined
#define B0 17 // 21+23+25+27 мл.разряд синего
In file included from C:\Users\User\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.6\cores\esp32/Arduino.h:41,
from sketch\ESP32-SDR-TRX.ino.cpp:1:
C:\Users\User\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.6\cores\esp32/binary.h:23: note: this is the location of the previous definition
#define B0 0
C:\Arduino\Sketchbook\ESP32-SDR-TRX\global.h:99: warning: "B1" redefined
#define B1 16 // 22+24+26+28 ст.разряд синего
C:\Users\User\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.6\cores\esp32/binary.h:31: note: this is the location of the previous definition
#define B1 1
C:\Arduino\Sketchbook\ESP32-SDR-TRX\global.h:17:1: warning: 'typedef' was ignored in this declaration
typedef struct FIR {
C:\Arduino\Sketchbook\ESP32-SDR-TRX\global.h:299:1: warning: ISO C++ forbids converting a string constant to 'char*' [-Wwrite-strings]
Скетч использует 526721 байт (40%) памяти устройства. Всего доступно 1310720 байт.
Глобальные переменные используют 90364 байт (27%) динамической памяти, оставляя 237316 байт для локальных переменных. Максимум: 327680 байт.
