Страница 116 из 176 ПерваяПервая ... 1666106113114115116117118119126166 ... ПоследняяПоследняя
Показано с 1,151 по 1,160 из 1755
Тема: Трансивер Flex-5000
  1. #1151
    Аватар для UA3VBD
    г.Юрьев-Польский
    1,255
    UA3VBD (ex UW3WO)
    О новой версии PowerSDR - http://www.mail-archive.com/flexradio%40flex-radio.biz/msg46874.html
    "...PowerSDR v2.3.5 будет доступна для скачивания 5 марта. Объявление будет сделано в понедельник с загрузкой деталей.
    Tim Ellison, W4TME..."
    73! Юрий UA3VBD (ex UW3WO), RDA:VL-28, QTH Loc:KO96UL, RCFA:UA-00370
  2. #1152
    G.Yarmouth (JO02UO)
    101
    M0NPQ
    FlexRadio Systems is pleased to announce the general availability of the
    newest release of PowerSDR, version 2.3.5 intended for use with the
    SDR-1000, FLEX-1500, FLEX-3000 and FLEX-5000 software defined radios.
    PowerSDR v2.3.5 has several new significant features, existing feature
    enhancements and bug fixes.
    Obtaining PowerSDR v2.3.5:
    To install PowerSDR v2.3.5, you must first download the software
    installer and release notes from the FlexRadio web site. PowerSDR
    v2.3.5 is not a maintenance release of version 2.2.3 therefore it is
    highly recommended that you review the PowerSDR v2.3.5 Release Notes,
    particularly the section "Known Issues or Recommendations with New
    Features Included in this Release", before installing and operating your
    software defined radio with PowerSDR v2.3.5. This release contains
    significant changes to PowerSDR's internal database schema and as such,
    there are some caveats related to importing data from previous versions
    of PowerSDR along with new database import requirements and compliance
    measures.
    PowerSDR v2.3.5 Installer:
    http://support.flex-radio.com/Downloads.aspx?id=393
    PowerSDR v2.3.5 Release Notes:
    http://support.flex-radio.com/Downloads.aspx?id=394
    New Enhancement Summary:
    1. Support for new channelized 60 meter band changes and the addition of
    a visual Channel Mode for PowerSDR.
    2. VAC for RX2 (VAC2). VAC2 is available only for use with the FLEX-5000
    equipped with a second receiver (RX2).
    3. The maximum VAC sampling rate (SR) has been upgraded to support 96
    and 192 KHz.
    4. Expanded TX Profiles now saves all significant transmit related
    PowerSDR settings.
    5. RX2 disconnect on transmit.
    6. TNF now works properly with ANF so both can be used in a
    complimentary manner.
    7. The management of Memories in PowerSDR has been improved to include
    an automatic DB backup and recovery mechanism in addition to committing
    memory changes to the memory DB on copy, add and delete operations.
    8. With this version of PowerSDR, a session specific and previous
    database backup is created for recovery purposes.
    9. PowerSDR Database import requirement compliance to prevent
    applications errors and anomalous behavior of your radio.
    10. There are six (6) new PowerSDR skins available. There are five new
    IK3VIG 2012 skins and a new default skin that is sourced from IK3VIG's
    excellent work.
    11. New CAT commands to support PowerSDR features.
    12. Updated FLEX-1500 USB driver
    Getting Support:
    If you have issues installing or operating PowerSDR v2.3.5 with
    FlexRadio's software defined radios, please contact FlexRadio Systems
    technical support by opening a HelpDesk ticket on-line at
    http://helpdesk.flexradio.c om or by phone at
    [COLOR=#49535A !important] +1 (512) 535-4713 [/COLOR]
    extension #2
    Our Technical Support engineers are available by phone Monday -- Friday
    from 8:00am-5:30pm Central Time. If you call after business hours or on
    a holiday or weekend, please leave a detailed message and we will return
    your call during regular business hours.
    You may always submit a HelpDesk support ticket at any time.
    If you need assistance opening a HelpDesk ticket, please refer to the
    following web page for detailed instructions. http://support.flexradio.com/
    -Tim
    Tim Ellison, W4TME
  3. #1153
    Аватар для RK1NA
    Петрозаводск
    3,694
    RK1NA
    Это мы знаем.
    Кто бы ещё грамотный перевод сделал?
  4. #1154
    Харьков
    8,877
    ex UR4IX
    Немного доработал скин "Default 2012", т.к. не люблю лишних рамок и переливов.
    Последний раз редактировалось UT4LW; 05.03.2012 в 16:10.
    Юрий. SDC website
  5. #1155
    Аватар для yl2gl
    Даугавпилс
    5,353
    YL2GL
    А закрасить пространство ниже линии развёртки возможно?
  6. #1156
    Аватар для RK1NA
    Петрозаводск
    3,694
    RK1NA
    Цитата Сообщение от yl2gl Посмотреть сообщение
    А закрасить
    Setup - Display - Fill Panadapter
    Последний раз редактировалось RK1NA; 05.03.2012 в 14:44.
  7. #1157
    Донецк
    7,141
    3
    Появились дополнительные возможности виртуального кабеля
    VAC 4.11 Registry Import
    This file is a Windows Registry file that will create seven (7) VAC 4.11 cables.
    The first 6 are used with PowerSDR in the VAC configuration and the seventh is used as the default sound card device if you do not have an active sound card in you PC.
    Скачать здесь Filesize: 6,768 bytes
    Донецк Александр
  8. #1158
    Аватар для RK1NA
    Петрозаводск
    3,694
    RK1NA
    Это шутка такая?
  9. #1159
    Донецк
    7,141
    3
    Цитата Сообщение от RK1NA Посмотреть сообщение
    Сообщение от Llll
    Это шутка такая?
    Нет это не шутка , именно 7 kb (маленькая утилитка)
    Донецк Александр
  10. #1160
    Аватар для RK1NA
    Петрозаводск
    3,694
    RK1NA
    Нет это не шутка
    Теперь не шутка.
    А то я заходил по ссылке - весь экран в красном - типа куда прёшь.
  1. Flex-1500
    от Llll в разделе Software Defined Radio (SDR), Digital Radio Mondiale (DRM)
    Ответов: 1660
    Последнее сообщение: 04.01.2024, 18:55
  2. Flex-3000
    Ответов: 1026
    Последнее сообщение: 21.04.2023, 09:24
  3. Трансивер SDR-1000 (Flex)
    Ответов: 1745
    Последнее сообщение: 25.03.2022, 07:47
  4. Flex-5000 vs Flex-3000
    Ответов: 22
    Последнее сообщение: 01.08.2014, 23:19
  5. Синтезатор в Flex-5000
    от RA3PKJ в разделе Software Defined Radio (SDR), Digital Radio Mondiale (DRM)
    Ответов: 371
    Последнее сообщение: 26.01.2013, 01:02
