Новое радио
PRELIMINARY
Frequency Range: 0.01 - 32 MHz *
Digital Down Converter: Xilinx XC3S500E
PC Interface: Ethernet 100 base-T (UDP/TCP/IP)
Filters: 32 bit ,120+ dB 90% Alias Free BW
Decimation Rate: Variable 70-2047
Output Sample Rate: 39 KHz to 1.15 MHz @ 24b IQ
Flatness: <0.1 dB
Dynamic Range: 105 dB
MDS: -132dBm in 500 Hz BW
Analog to Digital Converter: 16bit w/ Dither
Preselection: 10 Filters
Attenuators: 0, -10dB, -20dB, -30dB
Sample Rate: 80 MHz
Memory: 65536 x 16 bit samples
External Radio Control: Built-in RS-232 port
Dimensions: 210 x 70 x 180 mm
Display: 16 x 2 Character LED LCD
Power: 5 Volts DC @ 1.5 Amp **
Connections: 4 x BNC (RF In, Ext Ref, Trigger, IF Out) , RS-232, Pulse Out, Ethernet, Power.
Expansion: Internal Downconverter, Internal 10 MHz Phase/Frequency Lock.
Price (base configuration): Estimated MSRP $2999.00, EURO 2250
Прямая ссылка в файле.
