Ïîêàçàíî ñ 1 ïî 8 èç 8
Òåìà: Êâàðöåâûé ôèëüòð
    Àâàòàð äëÿ 4L1G
    Ðåãèñòðàöèÿ
    23.11.2005
    Àäðåñ
    Ñàãàðåäæî
    Ñîîáùåíèé
    3,034
    Ïîçûâíîé
    4L41RW
    Êâàðöåâûé ôèëüòð
    Îò êàêîãî òðàíñèâåðà Êâàðöåâûé ôèëüòð MF-31C 455 è êàêîãî åãî ñõåìà âêëþ÷åíèÿ.
    KE 77 KOKUSAI ELECTRC
    Ïîñëåäíèé ðàç ðåäàêòèðîâàëîñü 4L1G; 19.10.2010 â 11:56.
    Ïîòîìñòâî 41RW - Ãóïåíåö À.Ã., ã. Ñàãàðåäæî; 1928 ã. (AU7AO-SZ6)
    To: NRD 525 group
    Sent: Monday, March 15, 2004 1:24 PM
    Subject: [nrd-525-535] Filter impedance?
    Here is what I have on these filters:
    WIDE position: CFL-D6S ceramic, in/out impedance 2000 to 2200 ohms
    INTER position: MF-31C mechanical filter, in/out impedance 1500 ohms
    AUX or NARR position: YF455EBF crystal filter 1.8 KHz bandwidth, 600 ohms
    73, John Reed, KA5QEP
    My NRD- 535D from Universal Radio came with a CLFD8. I found this to
    be far to wide so I changed it to a CLFD6. But I found this to be a
    tad wide, so I installed a CLFD6S. The CLFD6 is good, but I'm
    basically a DXer so I like the CLFD6S.
    Now that brings up another bag of worms in which I could have messed
    up some things on my 535D. I changed some of the IF Filters in my
    535D. I configured the filters so to be narrow to wide in
    succession via the "Band Width button on the 535D. I now have the
    following in the following Filter Slots on my CFH-36A IF Filter
    Board ...
    FL3 - muRata CFS 455 I - No 07 69359
    FL4 - KE MF-31C
    FL5 - YF 455DE 0N01
    FL6 - CLF-D6S N 180X
    Other than Collins Mechanical Filters... What's Better than what I'm
    now using for Voice Quality (Clean) in or around the same KHz filter
    widths listed above ???
    Ïîëó÷àåòñÿ, ÷òî ýòî ÝÌÔ, Râõ/âûõ=1500 îì, îò NRD-535D... Ñõåìó ýòîãî ïðèåìíèêà íàéäèòå è ïîñìîòðèòå, êàê âêëþ÷àòü.
    Àâàòàð äëÿ 4L1G
    Ðåãèñòðàöèÿ
    23.11.2005
    Àäðåñ
    Ñàãàðåäæî
    Ñîîáùåíèé
    3,034
    Ïîçûâíîé
    4L41RW
    äàà!! òî÷íî ÝÌÔ! MF-31C 455.
    Ðåãèñòðàöèÿ
    20.04.2007
    Àäðåñ
    Òáèëèñè
    Ñîîáùåíèé
    1,483
    Ïîçûâíîé
    4L1FL
    Ãîñïîäà, êñòàòè, èìåþ ïîäîáíûé ôèëüòð, ïðè÷åì ÷àñòîòû ñðåçà ÒÎ×ÍÎ òàêèå æå , êàê è íà ìîåì êåðàìè÷åñêîì ôèëüòðå â òðàíñèâåðå FT-900 CFJ455K-15. Äàííûå âçÿòû èç îïèñàíèÿ íà NRD-525. Êòî èññëåäîâàë èõ õàðàêòåðèñòèêè? Èìååò ëè ñìûñë çàìåíà êåðàìè÷åñêîãî ôèëüòðà íà ýòîò ÝÌÔ? Ñ ó÷åòîì ïðàâèëüíîãî ñîãëàñîâàíèÿ, êîíå÷íî. Åñòü èäåÿ äîáàâèòü êåðàìè÷åñêèé ôèëüòð â ïðåäïîñëåäíèé ÓÏ×, äàáû ïîäðåçàòü øóìû ïðèåìíèêà.
    Àâàòàð äëÿ 4L1G
    Ðåãèñòðàöèÿ
    23.11.2005
    Àäðåñ
    Ñàãàðåäæî
    Ñîîáùåíèé
    3,034
    Ïîçûâíîé
    4L41RW
    Âîò åùå, ðàñøèôðóéòå ïîæàëóéñòà, íå ïîìíþ ãäå âçÿë..îò ÷åãî..
    Ìèíèàòþðû Ìèíèàòþðû Íàæìèòå íà èçîáðàæåíèå äëÿ óâåëè÷åíèÿ.
Íàçâàíèå:	IMG_8688.jpg
Ïðîñìîòðîâ:	435
Ðàçìåð:	115.2 Êá
ID:	85711   Íàæìèòå íà èçîáðàæåíèå äëÿ óâåëè÷åíèÿ.
Íàçâàíèå:	IMG_8691.jpg
Ïðîñìîòðîâ:	366
Ðàçìåð:	91.0 Êá
    Ðåãèñòðàöèÿ
    20.04.2007
    Àäðåñ
    Òáèëèñè
    Ñîîáùåíèé
    1,483
    Ïîçûâíîé
    4L1FL
    Äûê íà íåì æå âñå ñáîêó íàïèñàíî, îñòàëîñü "ïîãóãëèòü"... Âðîäå îò ÓÊÂ-åéêè êàêîé-òî êâàðöåâûé ôèëüòð íà 11,5 ìãö. Ôèðìà SEL. Òîëüêî áîëüíî óæ äðåâíèé...
    Ïîñëåäíèé ðàç ðåäàêòèðîâàëîñü 4L1FL; 25.06.2011 â 18:56.
    Àâàòàð äëÿ 4L1G
    Ðåãèñòðàöèÿ
    23.11.2005
    Àäðåñ
    Ñàãàðåäæî
    Ñîîáùåíèé
    3,034
    Ïîçûâíîé
    4L41RW
    â ãóãëè-ìîãëè åãî íåò, 11.5 è òàê ÿñíî, à ÷òî òàêîå 455 è 901 ?
    Âëîæåíèÿ Âëîæåíèÿ
    Ïîñëåäíèé ðàç ðåäàêòèðîâàëîñü 4L1G; 25.06.2011 â 19:03.
    Ðåãèñòðàöèÿ
    20.04.2007
    Àäðåñ
    Òáèëèñè
    Ñîîáùåíèé
    1,483
    Ïîçûâíîé
    4L1FL
    ß óæå òîæå ïîñìîòðåë... Íåò... Åñëè îò ÓÊÂ-åéêè, ïîðÿäêà 15 êãö... Áûëî áû 455, âîïðîñîâ áûëî áû ìåíüøå, à ó òåáÿ 445! À ýòî óæå äðóãàÿ ïåñíÿ... Ñìîòðåòü íàäî íà À×Õîìåòðå... ß ñàì áû ñìîã, íî òîëüêî ÷åðåç ìåñÿö, â îòïóñêå... Íà ðàáîòå åñòü Õ1-48. Ïîñìîòðþ è ñâîé òîæå.
    Ïîñëåäíèé ðàç ðåäàêòèðîâàëîñü 4L1FL; 25.06.2011 â 19:11.
Èíôîðìàöèÿ î òåìå
Ïîëüçîâàòåëè, ïðîñìàòðèâàþùèå ýòó òåìó
Ýòó òåìó ïðîñìàòðèâàþò: 1 (ïîëüçîâàòåëåé: 0 , ãîñòåé: 1)
Ïîõîæèå òåìû
  1. êâàðöåâûé ôèëüòð
    îò artemx â ðàçäåëå Òåõíè÷åñêèé êàáèíåò
    Îòâåòîâ: 913
    Ïîñëåäíåå ñîîáùåíèå: 04.05.2020, 14:58
  2. êâàðöåâûé ôèëüòð
    îò r062006 â ðàçäåëå Äëÿ íà÷èíàþùèõ
    Îòâåòîâ: 76
    Ïîñëåäíåå ñîîáùåíèå: 22.08.2014, 20:46
  3. ÊÂÀÐÖÅÂÛÉ ÔÈËÜÒÐ ÍÀ 465ÊÃÖ
    îò VOVA080808 â ðàçäåëå Äëÿ íà÷èíàþùèõ
    Îòâåòîâ: 17
    Ïîñëåäíåå ñîîáùåíèå: 15.07.2010, 09:10
  4. Êâàðöåâûé ôèëüòð íà 4 429,4
    îò Denis_111 â ðàçäåëå Òåõíè÷åñêèé êàáèíåò
    Îòâåòîâ: 1
    Ïîñëåäíåå ñîîáùåíèå: 22.04.2007, 05:42
  5. Êâàðöåâûé ôèëüòð
    îò àíàòîëèé Ï â ðàçäåëå Äëÿ íà÷èíàþùèõ
    Îòâåòîâ: 20
    Ïîñëåäíåå ñîîáùåíèå: 01.09.2006, 18:28
Âàøè ïðàâà
  • Âû íå ìîæåòå ñîçäàâàòü íîâûå òåìû
  • Âû íå ìîæåòå îòâå÷àòü â òåìàõ
  • Âû íå ìîæåòå ïðèêðåïëÿòü âëîæåíèÿ
  • Âû íå ìîæåòå ðåäàêòèðîâàòü ñâîè ñîîáùåíèÿ
