23 23 ... 1320212223
221 230 230
: TS 830S
  1. #221
      Victor
    18.02.2003
    559
    UR9IP
    4L1FL
    UR9IP!!!
    Skype-UR9IP.
  2. #222
    06.02.2008
    680
    R2BAM
    Victor
    450,
    450 . .
  3.  RA3WDK
  4. #223
      rw0ab
    04.10.2012
    330
    RW0AB
    , FT-101ZD. 500 , 4 450 , 330 , . , . 11 , .
    ex.UA0ABL since 1971.
  5. #224
    09.09.2006
    2,170
    Victor
    , , , 100500, 450,
    ebay, . - , .
    RA3BA
    450 . .
    , , 900-950 . , , 500 . 100 , 150 .
  6. #225
      Victor
    18.02.2003
    559
    UR9IP
    830 LSB USB , USB , , IF SHIFT , .
    UR9IP!!!
    Skype-UR9IP.
  7. #226
      RN3GP
    04.01.2008
    11,820
    Victor
    , USB LSB, .
    RN3GP ex UA3ZVC, RA3GGP.
  8. #227
      Victor
    18.02.2003
    559
    UR9IP
    RN3GP
    , USB LSB, .
    , FT-901DM , WIDTH,
    , WIDTH , , , 830 , IF SHIFT , , .
    19 ():
    USB/LSB Carrier Oscillator Alignment
    Stand the radio on its left side. Set the AGC to fast, Calibrator to on, RF-gain to maximum, IF￾Shift to zero, VBT to normal and tune the radio to zero-beat the Calibrator on one of the 25 KHz
    check points. The S-meter should quiver slightly as the radio is tuned through zero-beat. This is
    very close to the point where the 100 Hz {right-most} digit blinks between a "0" and a "9". The
    S-meter should indicate about S2 to S3 at zerobeat. If it does not, adjust the appropriate carrier￾oscillator adjustment through one of the access holes on the bottom of the radio. Switch to the
    opposite sideband and repeat the procedure.
    Victor; 24.09.2017 16:12.
    UR9IP!!!
    Skype-UR9IP.
  9. #228
      RN3GP
    04.01.2008
    11,820
    Victor
  10. #229
      Victor
    18.02.2003
    559
    UR9IP
    RN3GP
    FT901, , 200 , , ,
    UR9IP!!!
    Skype-UR9IP.
  11. #230
      RN3GP
    04.01.2008
    11,820
    Victor
    , FT-817 "" , , . -3 . TS-480, , .
: 1 (: 0 , : 1)
  1. 1-48
    RD3AY
    : 125
    : 27.02.2020, 19:20
  2. TS-830S
    RA3BA TS-830
    : 3
    : 05.04.2015, 23:33
  3. VX-10
    Wiktor
    : 3
    : 03.04.2008, 09:27
  4. 1-48
    Raskat
    : 2
    : 20.02.2008, 22:56
  5. : 6
    : 26.09.2007, 19:53
