Ïîêàçàíî ñ 1 ïî 1 èç 1
Òåìà: Ãåìèíèäû 2016
    Çàáëîêèðîâàí
    Ðåãèñòðàöèÿ
    15.12.2013
    Ñîîáùåíèé
    568
    Ãåìèíèäû 2016
    Äëÿ èíôîðìàöèè çàèíòåðåñîâàííûì, â ïðîâåäåíèè MS QSO (SWL):
    Ìåòåîðíûé ïîòîê Ãåìèíèäû, âûñîêàÿ èíòåíñèâíîñòü -ZHR=120, "âèäåí" ñ 4 ïî 17 äåêàáðÿ, ïèê ìàêñèìóìà 14.12.2016ã.
    ______
    UPCOMING METEOR SHOWERS: DECEMBER 2016
    December is, as usual, characterized by the return of one of the most active (and probably the most reliable) major annual showers: the Geminids.
    Geminids maximum is expected to occur on December 14th, 00h20m UT, with ZHR = 120 hr-1 at peak. Since the peak has shown slight signs of variability in its rates and timing in recent years, please note that the more reliably-observed maxima during the past two decades have all occurred within the range λsol = 261.5 and 262.4 degs, equivalent to 2016 December 13th, 08h UT to December 14th, 05h UT. Near-peak rates usually persist for almost a day, while fainter meteors should be most abundant almost a day ahead of the visual maximum. The Geminids peak is typically quite broad (thus ensuring a several-days-long period of good MS activity), although the rates sometimes decay fairly quickly after the maximum.
    ______
    ×àò, äëÿ ñêåäîâ è íàáëþäåíèé http://www.on4kst.org/chat/start.php
    p.s. õîðîøàÿ àêòèâíîñòü íà 50 è 144MHz óæå íàáëþäàåòñÿ ñ 10.12.2016
    Âñåì õîðîøèõ îòðàæåíèé!
    GL
    Ìèíèàòþðû Ìèíèàòþðû Íàæìèòå íà èçîáðàæåíèå äëÿ óâåëè÷åíèÿ.
Íàçâàíèå:	bn.jpg
Ïðîñìîòðîâ:	371
Ðàçìåð:	406.5 Êá
    Ïîñëåäíèé ðàç ðåäàêòèðîâàëîñü Igor@D66; 13.12.2016 â 02:20.
Èíôîðìàöèÿ î òåìå
Ïîëüçîâàòåëè, ïðîñìàòðèâàþùèå ýòó òåìó
Ýòó òåìó ïðîñìàòðèâàþò: 1 (ïîëüçîâàòåëåé: 0 , ãîñòåé: 1)
Ïîõîæèå òåìû
  1. Dayton 2016
    îò Serg â ðàçäåëå Êîëëåêòèâû è Ðàäèî
    Îòâåòîâ: 35
    Ïîñëåäíåå ñîîáùåíèå: 01.05.2018, 18:36
  2. Friedrichshafen_ 2016
    îò DL8RCB â ðàçäåëå Êîëëåêòèâû è Ðàäèî
    Îòâåòîâ: 24
    Ïîñëåäíåå ñîîáùåíèå: 03.02.2018, 16:39
  3. Òðàíñèâåð Þíèîð-2016
    îò RST-599 â ðàçäåëå Òðàíñèâåðû, ïðèåìíèêè ÊÂ/ÓÊÂ
    Îòâåòîâ: 28
    Ïîñëåäíåå ñîîáùåíèå: 06.09.2016, 11:29
  4. Rio-2016 ZV2016RIO
    îò Igor@D66 â ðàçäåëå DX-íîâîñòè
    Îòâåòîâ: 2
    Ïîñëåäíåå ñîîáùåíèå: 07.08.2016, 17:08
  5. SIRIO 2016 5/8
    îò R4IT â ðàçäåëå Àíòåííû
    Îòâåòîâ: 0
    Ïîñëåäíåå ñîîáùåíèå: 29.08.2012, 15:33
Âàøè ïðàâà
  • Âû íå ìîæåòå ñîçäàâàòü íîâûå òåìû
  • Âû íå ìîæåòå îòâå÷àòü â òåìàõ
  • Âû íå ìîæåòå ïðèêðåïëÿòü âëîæåíèÿ
  • Âû íå ìîæåòå ðåäàêòèðîâàòü ñâîè ñîîáùåíèÿ
