Ïîêàçàíî ñ 1 ïî 6 èç 6
Òåìà: RX iGate - orangepi rtl-sdr pymultimonaprs - íå ïîíèìàþ íîðìàëüíî ðàáîòàåò èëè íåò.
    Ïîëíûé íîâè÷îê â aprs, íî òåìà èíòåðåñíà.
    Ñîáðàë èç òîãî ÷òî áûëî â çàêðîìàõ ïðîñòåíüêèé aprs RX iGate.
    Æåëåçî: orangepi+rtl-sdr v.3
    Ñîôò: armbian,rtl_fm,multi mon_ng, pymultimonaprs.
    Âðîäå áû âñå íàñòðîèë ïðàâèëüíî, íà aprs.fi ìîé beacon ïîÿâèëñÿ, íî âîçíèêëî ñîìíåíèå ïðàâèëüíî ëè ãåéòÿòñÿ ïàêåòû èç ýôèðà â inet.
    Â ëîãå pymultimonaprs âðîäå âñå íîðìàëüíî, ïàêåòû ïåðåñûëàþòñÿ:
    Mar 12 09:10:02 localhost pymultimonaprs: Starting pymultimonaprs
    Mar 12 09:10:02 localhost pymultimonaprs: connecting... ('85.90.180.26', 14580):14580
    Mar 12 09:10:02 localhost pymultimonaprs: connected
    Mar 12 09:10:03 localhost pymultimonaprs: # javAPRSSrvr 4.3.0b06
    Mar 12 09:10:03 localhost pymultimonaprs: login R1BET-10 (PyMultimonAPRS 1.3.2)
    Mar 12 09:10:03 localhost pymultimonaprs: # logresp R1BET-10 verified, server T2CSNGRAD, adjunct "filter r/38/-171/1" filter r/38.0/-171.0/1 active
    Mar 12 09:10:03 localhost pymultimonaprs: sending: R1BET-10>APPM13,TCPIP*:=60 00.52NR03017.08E&PyM ultimonAPRS RX iGate
    Mar 12 09:10:03 localhost pymultimonaprs: sending: R1BET-10>APPM13,TCPIP*:>Ru nning on OrangePi 2E with RTL-SDR dongle
    Mar 12 09:10:13 localhost pymultimonaprs: rejected: RA1AMW>APU25N,WIDE2-2,qAR,R1BET-10:}RV1>APRS,TCPIP,R A1AMW*:!3812.62N/01530.02Er 145.575-600 t. 94.8 E.R.A. Sretto di Messina
    Mar 12 09:10:14 localhost pymultimonaprs: rejected: RA1AMW>APU25N,WIDE2-2,qAR,R1BET-10:}RV1>APRS,TCPIP,R A1AMW*:>MOMENTANEAME NTE ATTIVO SOLO IN SIMPLEX ECHOLINK CONFERENZA E.R.A.
    Mar 12 09:10:37 localhost pymultimonaprs: rejected: RA1AMW>APU25N,WIDE2-2,qAR,R1BET-10:}UA1CAS-10>APRX29,TCPIP,RA1A MW*:!6102.66NR03007. 65E& Rx-only iGate APRX 2.9.0+dfsg-1 Raspberry Pi
    Mar 12 09:10:38 localhost pymultimonaprs: rejected: RA1AMW>APU25N,WIDE2-2,qAR,R1BET-10:}UA1CCB-5>APMI04,TCPIP,RA1AM W*:@120740z6102.32N/03006.92E#WX3in1Mini Digi/I-Gate Priozersk
    Mar 12 09:10:41 localhost pymultimonaprs: rejected: RA1AMW>APU25N,WIDE2-2,qAR,R1BET-10:}UA1CCB-13>APRX20,TCPIP,RA1A MW*:=6102.58N/03007.79E_.../...g...t031r...p...P ...b10060h SmallMeteo
    Mar 12 09:10:42 localhost pymultimonaprs: sending: RD1AS-3>APRS,WIDE2-1,qAR,R1BET-10:;R7 RD1AS *051857z5951.63N/03019.29Er R7 RD1AS 145.775
    Mar 12 09:10:51 localhost pymultimonaprs: sending: RA1AMW-9>V0QQ02,RA1AMW*,WID E2-1,qAR,R1BET-10:`9U$!IN>/]šxt}=
    Íî ïðè ýòîì åñëè ÿ ñìîòðþ ïàêåòû îò R1BET-10 íà aprs.fi, òî âèæó èñêëþ÷èòåëüíî ïàêåòû îò ìîåãî ìàÿêà:
    ×òî ÿ äåëàþ íå òàê?
    Ïîñëåäíèé ðàç ðåäàêòèðîâàëîñü R1BET; 17.03.2018 â 16:33.
    Ìîäåðàòîð Àâàòàð äëÿ DL8RCB
    Ðåãèñòðàöèÿ
    13.08.2007
    Àäðåñ
    94157 Perlesreut
    Ñîîáùåíèé
    17,542
    Ïîçûâíîé
    DL8RCB
    Öèòàòà Ñîîáùåíèå îò R1BET Ïîñìîòðåòü ñîîáùåíèå
    íî òåìà èíòåðåñíà
    1.òåìà ÀÏÐÑ ñóùåñòâóåò ñ 2000 ãî ãîäà ñêîðî áóäåì îòìå÷àòü 2 ÑÐÎÊÀ
    2.ïîñìîòðèòå â ïàêåòàõ ó âàñ ïðèñóòñòâóþò ra1amw,rd1as ïîçûâíûå íàøèõ êîëëåã, ÿ áû ïîñîâåòîâàë îáðàòèòüñÿ ê Âàñèëèþ â ïåðâóþ î÷åðåäü,äëÿ êîíñóëüòàöèé
    3.ìåæäó òåì, íà÷èíàòü íàäî âñå-æå ñ ïðîñòûõ óñòðîéñòâ, (íàïðèìåð îáû÷íûé òðåêåð) è ïîñòåïåííî îñâàèâàÿ, à âû ñðàçó íà ãåéò çàìàõíóëèñü
    íèæå âàøè êàðòèíêè ÷åðåç IP
    â UIVIEW32 íå âèæó ïîêà
    Íàæìèòå íà èçîáðàæåíèå äëÿ óâåëè÷åíèÿ.
Íàçâàíèå:	1.jpg
Ïðîñìîòðîâ:	617
Ðàçìåð:	89.3 Êá
ID:	284896Íàæìèòå íà èçîáðàæåíèå äëÿ óâåëè÷åíèÿ.
Íàçâàíèå:	2.jpg
Ïðîñìîòðîâ:	620
Ðàçìåð:	262.1 Êá
    Çàáëîêèðîâàí
    Ðåãèñòðàöèÿ
    15.12.2013
    Ñîîáùåíèé
    568
    Öèòàòà Ñîîáùåíèå îò DL8RCB Ïîñìîòðåòü ñîîáùåíèå
    ..... Æåëåçî: orangepi+rtl-sdr v.3
    Ñîôò: armbian,rtl_fm,multi mon_ng, pymultimonaprs......
    Àíàòîëèé, à êóäà ïðîùå ? Âñ¸ äî áåçîáðàçèÿ ïðîñòî, êîìïàêòíî è â "äóõå âðåìåíè", UIVIEW32 - èñêîïàåìîå....
    Ðåãèñòðàöèÿ
    13.08.2007
    Àäðåñ
    94157 Perlesreut
    Ñîîáùåíèé
    17,542
    Ïîçûâíîé
    DL8RCB
    Öèòàòà Ñîîáùåíèå îò Igor@D66 Ïîñìîòðåòü ñîîáùåíèå
    Èãîðü, òû æå çíàåøü ó ìåíÿ òàêîãî æåëåçà íåò,
    "â äóõå âðåìåíè"çàíèìàëñÿ 15 ëåò íàçàä , åñëè åãî ëåíèãðàäñêèå êîëëåãè íå ïîìîãóò, òàê òû êîíñóëüòèðóé
    Çàáëîêèðîâàí
    Ðåãèñòðàöèÿ
    15.12.2013
    Ñîîáùåíèé
    568
    íàäî íàâ¸ðñòûâàòü, æåëåçî òî, êîïååøíîå, è ýíåðãî-ýêîíîìè÷íîå
    https://geektimes.ru/post/269444/
    http://radiochief.ru/radio/obzor-sdr...l-sdr-com-v-3/
    .....íó è íåìíîãî ãåìîðîÿ.....
    Ðåãèñòðàöèÿ
    13.08.2007
    Àäðåñ
    94157 Perlesreut
    Ñîîáùåíèé
    17,542
    Ïîçûâíîé
    DL8RCB
    íàäî íàâ¸ðñòûâàòü,
    à çà÷åì? êóäà ýòî âñå òåïåðü äåâàòü? ïîíàäåëàíî è ïî-íàêóïëåíî "êîñîé äåñÿòîê" òðýêåðîâ ìîäåìîâ îäíèõ GPS - îâ ïîë-øêàôà, âûáðîñèòü æàëêî, à ïðîäàæàìè ÿ íå çàíèìàþñü.
Èíôîðìàöèÿ î òåìå
Ïîëüçîâàòåëè, ïðîñìàòðèâàþùèå ýòó òåìó
Ýòó òåìó ïðîñìàòðèâàþò: 1 (ïîëüçîâàòåëåé: 0 , ãîñòåé: 1)
Ïîõîæèå òåìû
  1. Îòâåòîâ: 30
    Ïîñëåäíåå ñîîáùåíèå: 15.02.2021, 10:17
  2. iGate AVRT7
    îò RA4FHE â ðàçäåëå Àïïàðàòóðà APRS
    Îòâåòîâ: 27
    Ïîñëåäíåå ñîîáùåíèå: 08.03.2018, 08:04
  3. íå ïîíèìàþ íîâîé íàâèãàöèè â ôîðóìå
    îò R9LR â ðàçäåëå Òåñòîâûé ôîðóì
    Îòâåòîâ: 6
    Ïîñëåäíåå ñîîáùåíèå: 25.01.2018, 15:51
  4. Îòâåòîâ: 47
    Ïîñëåäíåå ñîîáùåíèå: 07.04.2015, 16:19
  5. Îòâåòîâ: 25
    Ïîñëåäíåå ñîîáùåíèå: 25.12.2011, 20:07
Âàøè ïðàâà
  • Âû íå ìîæåòå ñîçäàâàòü íîâûå òåìû
  • Âû íå ìîæåòå îòâå÷àòü â òåìàõ
  • Âû íå ìîæåòå ïðèêðåïëÿòü âëîæåíèÿ
  • Âû íå ìîæåòå ðåäàêòèðîâàòü ñâîè ñîîáùåíèÿ
