1 5 5
    12.09.2006
    , , KN34PC
    2,200
    LZ2WSG
    . - , . , , , . , . , hex .
    25-27 - ( ).
    Arduino " , , , , " - .
    Arduino hex/bin ... . , .. -- ... , , . , - . "" - S-, , CAT- . .
    , , , . ? 0,001%? ? , . .
    , : , , , , , ASM, C, CPP, (. GNU) PIC, AVR, Arduino, ARM . , : . , .
    22.11.2021
    37
    veso74
    veso74
      RK9AMX
    26.03.2005
    , MO05RE
    1,403
    20
    RK9AMX
    . . , : 0..99; 100..199; 200..299 .. , (150, 250, 350 ..).
    . PIC . . , PIC, .
    #define KEY_INP         0   //
    #define TIME_DEBOUNCE   30  //
    #define TIME_LONG_PRESS 800 //
    #define BUTTON_ACTIVE   950 //
    enum {not_press, short_press, long_press}; //
    #define B1S 1
    #define B1L 254
    #define B2S 2
    #define B2L 253
    #define B3S 4
    #define B3L 251
    #define B4S 8
    #define B4L 247
    #define B5S 16
    #define B5L 239
    #define B6S 32
    #define B6L 223
    #define B7S 64
    #define B7L 191
    #define B8S 128
    #define B8L 127
    uint8_t push_button = 0; //
    void setup() {
      Serial.begin(115200);
    void loop() {
      key_status(); //
      switch (push_button) {
        case B1S: Serial.println("B1S"); break;
        case B1L: Serial.println("B1L"); break;
        case B2S: Serial.println("B2S"); break;
        case B2L: Serial.println("B2L"); break;
        case B3S: Serial.println("B3S"); break;
        case B3L: Serial.println("B3L"); break;
        case B4S: Serial.println("B4S"); break;
        case B4L: Serial.println("B4L"); break;
        case B5S: Serial.println("B5S"); break;
        case B5L: Serial.println("B5L"); break;
        case B6S: Serial.println("B6S"); break;
        case B6L: Serial.println("B6L"); break;
        case B7S: Serial.println("B7S"); break;
        case B7L: Serial.println("B7L"); break;
        case B8S: Serial.println("B8S"); break;
        case B8L: Serial.println("B8L"); break;
      push_button = 0;
    void key_status(void) {
      static uint8_t    button_state;
      static int16_t    button;
      static uint32_t   count;
      if ((analogRead(KEY_INP) < BUTTON_ACTIVE) && (button_state == not_press)) {
        count = millis();
        button_state = short_press;
        button = analogRead(KEY_INP)/100;
      if ((button == (analogRead(KEY_INP)/100)) && (button_state != not_press) &&
        ((millis() - count) > TIME_LONG_PRESS)) {
        if (button_state != long_press)  push_button = ~(1 << button);
        button_state = long_press;
      if ((analogRead(KEY_INP) > BUTTON_ACTIVE) && (button_state != not_press) &&
        ((millis() - count) > TIME_DEBOUNCE)) {
        count = millis();
        if (button_state != long_press) push_button = 1 << button;
        button_state = not_press;
:	.png
:	60
:	43.5
    12.09.2006
    , , KN34PC
    2,200
    LZ2WSG
    ADF4351 4, , sleep.
    : 00: 144 MHz; 01: 430 MHz; 10: 432 MHz; 11: 435 MHz.
    : . Analog Devices ADF435x Software, .
    PIC12F508, CCS PIC-C Compiler
    veso74; 03.10.2025 10:53.
    12.09.2006
    , , KN34PC
    2,200
    LZ2WSG
    ATtiny10 (0..15V), , TM1637, SW I2C ( , )
    ADC ATtiny10 - 8 . ADC oversampling - / . 256 (+4 ). : ​​ 64 .
    0..15V 5V ADC.
    Arduino IDE v1.8.19 + ATtiny10Core, : USBasp ( USBasp - USB programmer for Atmel AVR controllers, Thomas Fischl), hex AVRDUDESS.
  6.  RK9AMX
: 1 (: 0 , : 1)
  1. CAD
    ledum
    : 1
    : 17.05.2017, 10:58
  2. SDR,
    alex.petukhov Software Defined Radio (SDR), Digital Radio Mondiale (DRM)
    : 14
    : 17.06.2016, 15:23
  3. UI-VIEW32
    DL8RCB
    : 36
    : 22.10.2011, 20:22
  4. DS1621
    RIT
    : 10
    : 27.02.2010, 08:01
  5. extrawork1
    : 0
    : 31.07.2008, 17:21
